Old 03-26-2015, 07:24 PM   #1
2109S or 2104S Shower Size
Can anyone tell me the measurements of the floor pan in the shower on either a 2109S or 2104S please? There aren't any with that shower anywhere near and want to see how big it is.
Thanks in advance
itgoes211 is offline   Reply With Quote
Old 03-26-2015, 07:41 PM   #2
Do you need the floor plan or shower pan measurements??
Henboy is offline   Reply With Quote
Old 03-26-2015, 07:43 PM   #3
Sorry.. I meant to say floor pan... I would like the measurements of the shower base.
Thanks so much
Old 03-26-2015, 08:55 PM   #4
I will get it for you tomorrow morning.
Old 03-27-2015, 06:11 PM   #5
Shower dimensions, 2014 Flagstaff 21FBRS:Wall to outside edge: 25.5" each way. Corner cut-off 14" outside.Inside pan: 23.5" each way. Corner cut-off (45*) 12" inside.Small but it works. We use it only when boondocking or the park we are in has poor bathing facilities.We suggest you plan on Wet/Off/Soap/Rinse/Off. You will need a cut-off valve installed in the hose to avoid having to dial the water temperature in each on/off/on cycle.
Old 03-27-2015, 06:15 PM   #6
Thanks so much for the detailed measurements. WOW that's a tight shower....
Old 03-27-2015, 06:23 PM   #7
Yes it is. The only real negative on a teriffic floor plan.It takes a little practice to keep the shower curtain in rhe pan and water off the floor. We found that an aftermarket curtain is necessary to do the job.
Old 03-27-2015, 06:55 PM   #8
Also splash guards. Purchased mine at Lowes or Home Depot; they help keep the curtain in.
Papa GLS is offline   Reply With Quote
Old 03-27-2015, 07:44 PM   #9
Life Without Whine's Avatar
we have nothing added or changed ....just really conscious of taking aim with the water spray (and a bath mat to step out on may be helping a little too!)
Terri & Joe, Roxie & BrewDog Boont
Camping on average a long weekend every month since starting in May of 2013 .... Florida is a great state to have this bad habit
Life Without Whine is offline   Reply With Quote
210, 2109s, show, shower
