Old 07-14-2015, 09:05 PM   #11
The older models slide on from the end. The newer ones use the tilt on method. Don't know exactly when it changed. Our 2012 Roo had the slide on. Our 2016 Mini Lite has the tilt.
2011 Traverse LT, 3.6L, FWD
Old 07-14-2015, 09:11 PM   #12
Originally Posted by aceinspp View Post
... It's about worthless and dangerous.
How is it dangerous and what is your basis?
We've used ours for 7 yrs hanging on the rail and no evidence of any harm to the trailer or awning which is always out while it is in use.
Old 07-14-2015, 09:16 PM   #13
TURBS's Avatar
Originally Posted by Shinbone View Post
Thanks Turbs, I didn't realize that. Does it just hang from the top edge?
No it will still clip under.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 07-14-2015, 09:18 PM   #14
I'm pretty sure mine just hangs from the top edge. I don't THINK it clips. (I've only used it once, so bear with me.)
Old 07-14-2015, 09:21 PM   #15
TURBS's Avatar
Originally Posted by rockfordroo View Post
Mine just hangs from the top edge. I don't THINK it clips. (I've only used it once, so bear with me.)
My old 05 flagstaff tt as well as my 11 sabre 5th wheel have the same rail.
If you lift the bottom of grill mount and set top in the upper groove then bring mount down it will lock into rail.
Done it a hundred + times.
To dark to take pictures tonight.
Tomorrow.
TURBS
2011 32bhok Sabre
Old 07-14-2015, 09:23 PM   #16
The hanger is C shaped and once it clips over the top, the bottom goes under the bottom of the rail. If you look closely, the bracket is curved on the top and L shaped on the bottom.
Old 07-14-2015, 09:26 PM   #17
TURBS's Avatar
I agree.
TURBS
2011 32bhok Sabre
Old 07-14-2015, 09:43 PM   #18
trudinator's Avatar
Always curious as to why peoe don't use the grill on the bracket. This is our 5th year. Never had an issue with it melting the TT or the awning.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 07-14-2015, 09:44 PM   #19
TURBS's Avatar
Use ours every single time we camp!
TURBS
2011 32bhok Sabre
Old 07-14-2015, 10:42 PM   #20
If it's the same old rail they have been using for years. Just tilt it on. Mine is 2012. My neighbor has a 2015 same rail.
10Boomer is offline   Reply With Quote
210, 2109s
