Old 07-24-2019, 09:36 AM   #1
jdhreiss's Avatar
2304ds stress crack in "windshield"
I've read the thread on rock chips in the front windshields, but I recently found a 10" crack starting at the "8 o'clock" edge of the glass, heading toward the windshield's center. There were no rock chips in the window. After a trip over the mountain passes in Idaho - where there were numerous construction areas and rough roadways, I'm wondering if this is a crack from the twisting/bouncing of the trailer. Anyone have a similar problem?
Joe R.
SW Washington
2013 F150 Super Crew 5.0
2019 Rockwood 2304DS
1975 Chrysler Imperial
jdhreiss is offline   Reply With Quote
Old 07-24-2019, 10:03 AM   #2
tonyz1's Avatar
Didn't see what year your 2304ds was but on our 2018 29ksws the windshield cracked from near the corner up diagonally for about a foot while sitting beside our house over the winter. Forest River replaced ours (no charge), they seem to have had some problems with them not being finished right around the dges or something like that. Just what happened to us.
tonyz1 is offline   Reply With Quote
Old 07-24-2019, 11:57 AM   #3
I used to have a van with a huge windshield. Windshields were changed like I changed oil, frequently.
Problem was explained to me by a "glass man". Many windshields are prone to getting slight edge chips as they are handled (larger ones are harder for individuals to handle so more prone). Larger ones are also subjected to more wind pressure at highway speed creating stress in the window. The chip on the edge is a "stress riser" and cracks often start from that point and grow. How far? Depends on how far the crack has to grow to relieve the stress.
Just sharing an explanation that has a lot of logic to it.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 07-24-2019, 06:43 PM   #4
jdhreiss's Avatar
Stress crack
Thanks, guys. The dealer (Vancouver RV in Washington) has been great on my last 2 purchases. The photos tell the tale. We will see. The trailer is a 2019 I purchased in October. it has about 3,500 miles in it.
Name:	window trailer1.jpg
ID:	210725   Click image for larger version
Name:	window trailer.jpg
Joe R.
SW Washington
Old 07-24-2019, 07:03 PM   #5
Am I seeing things or is the edge of the windshield ground off with a bevel?
From the picture it looks like it might have been done with a sanding disc. If so I'll bet that they see a lot of cracks like this. I believe most automotive windshields are edge finished using a "wet grind" much like eyeglasses which leaves shallower "scratches" that don't create stress risers.
Just curious if it is roughly ground or I'm just seeing things in the picture.
2004 Nissan Titan
Old 07-25-2019, 01:53 PM   #6
jdhreiss's Avatar
Stress crack
The edge is rounded and looks / feels smooth enough. The glass looks like it is glued in, which would limit movement. I'll do a little research on glue-in windshields vs stress breakage.
Name:	window trailer close.jpg
Joe R.
SW Washington
2304, crack
