Old 06-12-2018, 01:36 PM   #1
PARADOX-SEV's Avatar
2304DS Toilet Upgrade
I'm looking to replace the Dometic 300 toilet in my trailer with a 310. The rough in is 8.5" for the 300 and 10" for the 310. The toilet is angled and one side is about 9" and the other side about 11". Has anyone upgraded their toilet to a 310?
2017 Rockwood Ultra Lite 2304DS
2014 Chevy Silverado 1500 6.2L
PARADOX-SEV is offline   Reply With Quote
Old 06-13-2018, 12:39 AM   #2
immecor's Avatar
Subscribed. I have the same trailer and was curious about this as well. Hopefully someone will have some info.
2017 RW 2304DS
2011 Expedition w/HD tow package
immecor is offline   Reply With Quote
Old 06-13-2018, 03:46 PM   #3
I was hoping for a better response. I guess I'll go buy one and hope I can return it if it doesn't fit.
Old 06-14-2018, 12:28 AM   #4
immecor's Avatar
I hear you. Not much mention of the 2304DSs. I would love to here how it goes. . Any other mods that youíve done? So far the biggest thing Iíve done is the MorRyde steps and tool box.
2017 RW 2304DS
Old 06-14-2018, 09:17 AM   #5
Its a work in progress. I threw out the old mattress and went with a memory foam from Amazon. Replaced the door window with tinted window from Ross RV Innovations. Took out every drawer and glued and screwed the bottom and sides. Replaced the shower head with an Oxygenics and lastly installed a LevelMatePro. I'm looking to upgrade steps as well. Been looking at the SolidStep and Torklift.
Old 06-14-2018, 09:53 AM   #6
Since its installed at a angle to the walls you "Should" be OK! What "SEAT" are you getting? If Plastic I feal sorry for You! Youroo!!
Old 06-14-2018, 12:47 PM   #7
immecor's Avatar
The wife and I are really happy with the new steps. They feel nice and solid. Need to figure out how to light them up now.
I have a few goodies to install this weekend. SlimShade, RVLock v4.0 and the Heng's RV Chandilier. Hopefully all will go smooth. I was considering the LevelMatePro just haven't pulled the trigger on that one yet.
Yeah, the bottom of the lower larger drawers fell out so I added some plywood to the bottom with tons of glue and staples. Maybe I will do the other large drawer this weekend as well as a precaution.
Old 06-14-2018, 01:03 PM   #8
I'm thinking the angled back on the 310 should clear the wall. It has porcelain bowl with slow close wood seat and lid.
Old 06-14-2018, 01:25 PM   #9
DAISY BOYKIN's Avatar
Installing upgrade toilet
I just completed the upgrade to the 320. My Rv is Rockwood Fifth wheel 8285WS. I was concerned with clearance of the upgrade. The 310 says you need 10 inches from center of the sewer hole to the back of the 310 toilet.
The sealing gasket is large enough to slip the 310 toilet forward away from the back wall by 1/2". You can also slip the 310 toilet 1/2" from side to side.
That is about all you have to work with outside the measurements that is required by Dometic for the 310
Good Luck.
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 06-14-2018, 01:42 PM   #10
Originally Posted by DAISY BOYKIN View Post
I just completed the upgrade to the 320. The only difference between the 310 & 320 is color. My Rv is Rockwood Fifth wheel 8285WS. I was concerned with clearance of the upgrade. The 310/320 says you need 11 inches from center
of the sewer hole to the back of the 310/320 toilet. My measurement was 10 1/2" from center of sewer hole to the wall.
The sealing gasket is large enough to slip the 310/320 toilet forward away from the back wall by 1/2". Another words, I made it fit. It was close. the 310/320 toilet can be slipped left/right by 1/2" & front to back by 1/2".
That is about all you have to work with outside the measurements that is required by Dometic for the 310/320 toilet.
I did not have a problem with the side to side, plenty of clearance.
But the rear clearance for the rear is MINIUM OF 10 1/2".
The back of the 310/320 is flat across the back, it is not round.
Good Luck.
The 310 is a round bowl and the 320 is elongated. Both are available in White or Bone.
2304, upgrade
