Old 04-12-2016, 06:46 PM   #1
Bowhunter831
Smile 2304ks Rockwood Mini
Question on battery disconnect. Doesn't seem to matter if it is in on or off position lights still work inside? Assume ON means batteries are in disconnect? Also my propane detector beeps and flashes red to green when in battery mode? Read pamphlet that said have low voltage but batteries show charged on panel inside trailer.
Love the trailer only issue is small leak over bathroom window sealed with clear silicone still very minor leak tightened window crank very tight stooped leak. Had 3" of rain two days ago no leak.
Only complaint is bathroom shower stall seems pretty flimsy.
Pete Peters is offline   Reply With Quote
Old 04-12-2016, 07:38 PM   #2
Battery disconnect on=on off=off. If you can remove the key/handle it is off/disconnected. You really can't use the idiot light for the battery they are never accurate.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 04-12-2016, 09:31 PM   #3
My battery disconnect works fine. When I turn it off no current at all in the rig. Had a small leak by the shower door, used clear Flex Seal and problem solved. Everything else is fine.
Enjoy your rig.
bailer6334 is offline   Reply With Quote
Old 04-13-2016, 08:26 AM   #4
Bowhunter831
Thanks since lights still work in disconnect mode I wonder if dealer has batteries hooked-up wrong.
Old 04-13-2016, 08:31 AM   #5
Bowhunter831
We are taking trailer on a 2 1/2 month trip from MO to Alaska in June just want to make sure ever thing is working. Will be doing some dry camping in National Forest campgrounds. May take a Honda generator with me. Not worried too much about AC but would help keep batteries charged.
2304, rockwood
