Old 11-22-2010, 01:25 PM   #1
2304s slide out question
We have just purchased a new Rockwood 2304s TT and after reading the manuals on everything I could not find the place where to manually crank in the slide, if the need ever arises. It came with a crank that is about 2 feet long.
The owners manual is not very good at point out such how to do this.
jwuertz is offline   Reply With Quote
Old 11-22-2010, 01:45 PM   #2
Does the couch reside in the slide if so it is under there.
2015 Dodge Ram 1500 Quad Cab 4WD w/trailer pkg
345HP 5.7 Hemi/8spd Auto/3.73 Rear
2010 Roo 23SS
Prodigy Brake Controller
Equal-i-zer WD Hitch
2003 Harley FXDX Super Glide
browne02 is offline   Reply With Quote
Old 11-22-2010, 03:15 PM   #3
The U shaped dinette is in the slide.
Old 11-22-2010, 03:53 PM   #4
Do you have the power tongue jack, made by Lippert? If so, that crank handle goes to that- remove the black top cap, and it fits in the slot to manually fix overextending the worm gear drive mechanism. Believe me, I've had to use it several times! It may also fit the slide outs, but the manual crank-out would be under the unit, IMO. I read you must remove the motor to do it, but not sure, myself. Randy
Old 11-22-2010, 05:06 PM   #5
on my 8313 it is on the gearbox the motor is attached to. I do not have to remove my motor to manually open or close. it is a pin about 1/2" dia and maybe 1" long with a pin thru it to engage the crank. Yours may be different. Hope this helps.
Bill And Theresa Perry, At Lake Gaston
2004 R Vision Trail Lite
2003 F 150 Super crew with 5.4 Tow package
bill and theresa is offline   Reply With Quote
Old 11-23-2010, 11:23 AM   #6
Thanks every one for the info. I searched the net for the Dexter website, which is the manufacturer of the slide out hardware on the 2304S we have and it said that on some of the models the manual crank was on the oppsite side of the trailer in back of the steps. Next time I get out to the farm where the TT is store i will check that out.
This is a pretty neat website. I have learned a lot about RV's since I joined a week ago.
Old 12-04-2010, 04:37 PM   #7
AlWaysSumptin's Avatar
On the 2304S it's under a cover on the belly. Need a socket and ratchet to move it.
AlWaysSumptin is offline   Reply With Quote
Old 12-05-2010, 10:27 AM   #8
Thanks for the reply. I will have to get under the TT and check it out. Hopefully I will never need to retract the slide manually.
2304, rockwood
