Old 12-12-2014, 04:37 PM   #1
MTA
2503S waste water drain
We presently have a minilite 2109s and are thinking about moving up to a 2503s. Was wondering if anyone has had problems with the drain line busting off of the 2503s or any camper similar to this. It seems to sit pretty low to the ground. Was curious if anyone has had this problem before we make a move up to this camper.
MTA is offline   Reply With Quote
Old 12-12-2014, 05:20 PM   #2
I thought the one on the 2109s was low already.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is online now   Reply With Quote
Old 12-13-2014, 06:28 AM   #3
MTA
Indeed it does. I should have been more detailed. I was really referring to where the location of it is. If you look at the 2503s it sits back away from the axle a couple more feet and appears to have alot more exposure.
Old 12-13-2014, 06:58 PM   #4
Charliec's Avatar
We have a 2015 2504S that we hav used 5 times since we picked it up in October and have not had any problems with the drain or anything else. Great TT.
Charlie C
2012 Ford F-150
2015 Rockwood 2504S
Charliec is offline   Reply With Quote
Old 02-20-2015, 10:34 AM   #5
I too have the 2503s, and was wondering the same thing. I cant figure out why they placed it so close to the ground. Its only a matter of time before it gets ripped off, or you hit something on the interstate.... poor design I must say.
copwad is offline   Reply With Quote
Old 02-20-2015, 10:46 AM   #6
geotex1's Avatar
There's not much in the way of options for it between ducking below the frame rail and having slope for positive drainage on the long length needed from the grey tank.
Members in our camping club have one, and never had any issue with obstructions. However, a blowout of the left driver's side rear tire (another story altogether but it's having axles replaced) took out all of the piping and the valve. Luckily, they were on their way home from camping! They had, and I think wisely, re-plumbed using separate valves for the black and grey tanks and now they are tucked more tightly to the frame rail.
geotex1 is offline   Reply With Quote
drain, water
