Old 06-27-2016, 12:39 AM   #11
When you get your 2504s be sure to double check they closed the bypass valve coming out of your water heater. I didn't know this and had only Luke warm to coldwater for awhile.
Illumuss is offline   Reply With Quote
Old 06-28-2016, 08:33 PM   #12
Originally Posted by rcgray31 View Post
Thanks everyone for your feedback We took the plunge! We put our deposit down on a 2016 2504S!
I have one other question. Do you know what the GVWR is? We can't find it anywhere online. Just the dry weight.
Keep in mind it varies a bit depending on options you picked and material's used. This is mine GVW 6609 dry 4786 cargo 1764 you're trailer is weighed at the end of assembly.
The numbers won't add up..... They don't count the 60lbs of propane against the cargo weight.
Grizzzman is offline   Reply With Quote
Old 08-18-2016, 12:36 PM   #13
2017 Rockwood 2504S
Hello, I'm new here and this is my first post. We just purchased a 2017 Rockwood 2504S and are loving it. The GVWR is 6312#, perfect for our F150. So much packed into a small size but the dinette slide and murphy bed adds so much room. Most of the time its just me, my husband and our dog but we have plenty of room for grandkids. We started with a tent many years ago, upgraded to a popup and then a Wilderness 22U with no slide which we had for 14 years.
TXredbird is offline   Reply With Quote
