Old 04-24-2015, 02:25 PM   #1
2504s order or buy one on the lot?
I'm torn on what to do. Love the floor has one on the lot price is good, only thing I would change if I ordered is upgrade the AC from the 13.5 to the 15. Not sure how necessary that would be but being in Florida I figure more can't hurt. Also the interior have 2 kids not sure if I will prefer the cloth couch or "leather appearing" couch. Opinions welcome.
JWall115 is offline   Reply With Quote
Old 04-24-2015, 02:26 PM   #2
Jestercyco's Avatar
Upgrade to the 15, you will not be sorry.
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
Old 04-24-2015, 11:52 PM   #3
geefhoust's Avatar
I had the 13.5 a/c in my 2306 Mini Lite and it was more than enough. I pick up my Ultra Lite 2905ss on Monday and it has the 13.5 as well. I kinda wish it had the 15k upgrade since it's 10 feet longer than my Mini Lite was, but I wanted this one that was on the lot. If you found the trailer that you like and it's in stock then I wouldn't let the 13.5 a/c keep me from getting it.
2016 Ultra Lite 2905SS
2014 Chevy Silverado 2500HD
geefhoust is offline   Reply With Quote
Old 04-25-2015, 07:00 AM   #4
Big difference in OH summers and FL ones
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
220Chap is online now   Reply With Quote
Old 04-25-2015, 07:33 AM   #5
The_Rhino's Avatar
While in college in FL I spent 1 summer in a mobile home & like most TTs it was difficult to keep cool... Therefore I recommend the 15 A/C combined with a good MaxxAir fan, etc. that can run on 12V while you are traveling in the afternoon heat. When you arrive at your destination, the inside won't be hotter than the outdoor temps & your 15 A/C can reach comfy temps sooner.
2011 RAM 2500 ST Crew Cab 5.7 Hemi
2011 Primetime 3150BHD Touring Edition
Days camped in 2016-36
Days camped in 2015-37; Days camped in 2014-31
The_Rhino is offline   Reply With Quote
Old 04-25-2015, 07:45 AM   #6
Flybob's Avatar
Advantages of buying off the lot.
You can see exactly what you are buying. Specs change and a new one may have different equipment. You won't have delivery damage surprises that can delay picking it up. You get to enjoy all of 2015 camping season
Disadvantages You may not get exactly what you want.
Negotiate. Replacing an AC is not difficult or expensive. Ask dealer to upgrade as part of the deal and take the one on the lot. A new Duo Therm Brisk Air II 15K can be had for $600-$700 without trade in.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 04-25-2015, 12:18 PM   #7
Get the 15K - it is significantly more effective in hot humid climates. Another consideration, some 13.5K units will run on a single 2K watt generator (e.g., Honda or Yamaha). The 15K unit will likely need a larger wattage genset (3K or more).
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 04-25-2015, 12:31 PM   #8
Stormrider151's Avatar
When I bought my hybrid I had them change the 13.5 to a 15 K. The dealer said it wasn't necessary but I insisted. Now they all have the 15K here in Georgia as standard equipment. In Florida I would absolutely go for the upgrade.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 04-25-2015, 02:21 PM   #9
As an ex-air conditioning mechanic, let me chime in.
Sometimes larger is actually worse. Here's why...
When you have a large evaporator (the cool side coil), it tends to satisfy the thermostat sooner. But when it does, it doesn't run the fan long enough to remove humidity from the air. This has the effect of making the interior air feel cool and clammy, because there is still moisture in the air. It feels clammy because your skin doesn't evaporate your sweat as effectively as when you are in dry air.
A smaller AC running at longer cycle times can actually make you feel cooler because it has time to remove water from the air, making the interior humidity lower. Large units that are oversized for the load WILL keep the air cool, but won't necessarily keep YOU cool and comfortable.
There are excellent references for how this all works, but the most important thing is how well your camper is insulated. If poor insulation, the you most certainly will want the larger unit, because it will keep up with the extra load caused by poor insulation. And if it runs all the time, then it will also remove moisture. But if insulation is good, a smaller unit would be preferable, provided it is sized right for the cubic feet of the camper's interior.
MOODMAN is offline   Reply With Quote
Old 04-25-2015, 06:32 PM   #10
satdog01's Avatar
Dealer upgraded mine as part of the deal at no cost, did not take long.for the change out. Used the ole how much area you gain with slides out. Also means more to space to cool down when we travel to LA. Beat waiting weeks to order on. In fourth year of new unit without any av issues.
Marriot2 on Wheels 2017 Flagstaff Classic 832 OKBS
2013 GMC Denali 6.6L 2500 HD DMAX w\Alison Trans
Pepper Pomeranian rescue 101 days as camping buddy
Days camped in FR, 2011 = 20, 2012 = 57, 2013 = 59
... 2014 = 39, 2015 = 52, 2016 = 68, 3 more planned
Retired :
satdog01 is offline   Reply With Quote
