Old 10-14-2017, 11:50 AM   #1
mini-me's Avatar
2507 Carbon Monoxide with Gas water heater!
Just returned from our first vacation, 2 weeks, with our new 2507. Everything worked great all vacation until we got to the last weekend where we were dry camping at a Nascar race and had to use our gas water heater. After 20-30 minutes of use, the carbon monoxide detector alarmed. Has anyone had this issue. Wondering if it is connected wrong or just too close to the heater.
mini-me is offline   Reply With Quote
Old 10-16-2017, 10:26 AM   #2
Any water heater fumes should be venting outside. I think that detects propane as well, are you sure there's no leaks?
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 10-16-2017, 04:37 PM   #3
Key word - dry camping. How much of a charge did your battery have? A battery with a low charge will cause the carbon monoxide detector to start chirping.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 10-16-2017, 09:47 PM   #4
mini-me's Avatar
It wasn't chirping, it was definite alarm. And it was the co portion not the propane. Either way, if you read my newest post, it's not going to be an issue, getting a slightly newer model. We will mention it to the dealer though and will watch for it in the new one.
Thanks for the replies.
gas, heater, water, water heater
