Old 10-08-2017, 09:52 AM   #1
2507s wifiranger sky switch location
Just picked up my brand new 2507s Tuesday...did the PDI but the tech ahd no info in the new wifi ranger install...does anyone know where the wifi ranger switch location is in the trailer??
AV8RJohn is offline   Reply With Quote
Old 10-08-2017, 09:27 PM   #2
Aviator,
I had the same problem finding the Wi-Fi Ranger switch on my 2706WS. On mine, it was an unlabeled switch on my main switch panel. There was a small wi-fi Ranger decal on the wall just under the switch. The whole wi-fi Ranger assembly is located on your roof.
Ken
2018 Rockwood 2706WS
2007 Ford F-350
rvee-nut is offline   Reply With Quote
Old 10-08-2017, 09:36 PM   #3
Thanks!....found it... unmarked on/off switch above the radio panel
Old 10-09-2017, 09:48 AM   #4
Curious, what is the wifi ranger? What is it used for?
Tlynn is offline   Reply With Quote
Old 10-09-2017, 09:50 AM   #5
It's a router that boosts WiFi signals...new device installed in some Forest River trailers
Old 10-09-2017, 10:00 AM   #6
Thanks, I will be getting a new 2018 Forest River so hopefully mine will have it.
Old 10-09-2017, 12:49 PM   #7
Now Camping Year-Round!!
WannaBcamping's Avatar
Can the WiFi Ranger be added after market? Any idea the cost?
Also anyone used theirs to see how much of a difference it makes pulling in a signal than without it?
Cathy & Fraser - Ontario, Canada
2020 RW Signature 8291RK 5er (...May 2021) & 2017 Dodge Ram Laramie 6.7L Cummins Turbo Diesel 4X4
Still missing my beautiful Columbus2013 Columbus 325RL__2019 Rockwood 2511S__2017 Rockwood ML 2507S__Rockwood Roo 21RS__2009 Wildcat 29RLBS
WannaBcamping is offline   Reply With Quote
Old 10-09-2017, 01:49 PM   #8
WannaB -
Yes, you can add the WiFi Ranger as aftermarket. Go to their website for information. It's just a wifi booster, base level. They have more sophisticated models. Many companies make this kind of product. The main advantage here is that it is factory installed on the roof with the cables run internally.
I haven't used mine extensively, but it seems to work as advertised. It does a good job of boosting a weak wifi signal. I can get a decent signal as I walk around outside the trailer. You have to log onto the wifi ranger, then pick one of the wifi networks it sees. Log onto that network (or just connect to a free one) to connect to the internet.
Ken
2007 Ford F-350
Old 10-09-2017, 02:14 PM   #9
They product on my trailer is the sky3. If you go to wifiranger.com, then click on the OEM link, you'll see the sky3 compared to the other products. It lists a range of 0.5 mi., 2.4 Ghz. We did not get the "pack" version with the external USB/ethernet box.
Ken
2007 Ford F-350
Old 10-09-2017, 06:15 PM   #10
Nurek's Avatar
All these boosters do nothing when some of your neighbours start streaming Netflix or whatever and that chokes down the bitrate.
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
Nurek is offline   Reply With Quote
cat, location, switch
