Old 07-30-2019, 09:05 AM   #1
Question 2509s Tongue Weight
Hey Guys,
For those of you that own the above, can you sound off w/ your trailer weight and corresponding tongue weights? I'm very interested to see what the average tongue weight percentage is.
I want to make sure my truck won't run out of payload if I decide to stretch for this model over a Roo.
Thanks much.
s1njin is offline   Reply With Quote
Old 07-30-2019, 10:52 AM   #2
Grammar Pedant
67L48's Avatar
With the 2509S, there isn't that much CCC, so it's prudent to assume you'll be at the GVWR of the trailer = 6,800 lbs.
Proper loading will place no less than 10% onto the hitch and no more than 15%. Therefore, the range of weight onto the hitch will be 680 - 1,020 lbs. I would budget around 850-900 lbs onto your hitch.
2509S is a bunkhouse, so I'll assume 2 kids. That's 350 lbs for the parents and 150 for two kids = 500 lbs. Add 50 lbs of WDH and 150 of other gear, wood, and anything else in the bed.
So, to tow a 2509S, you'll want a truck with at least 1,600 lbs of payload. I have the same trailer weight, but 3 kids, I carry lots of wood, and a couple of bikes. I landed in the 1,800 - 1,900 range for the optimal payload for my needs.
Good luck.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is online now   Reply With Quote
Old 07-30-2019, 11:58 AM   #3
Yep, I had already figured worst case scenario based on the math you have above. My truck has 1797 (basically 1800 yah I know) pounds of payload w/ the Max Tow heavier duty rear axle.
I just don't want to consider this trailer heavily, have my family fall in love with it, and then screw myself on the pull home. I figure if most folks end up around the 12%-13% tongue that buys some pounds back.
Old 07-30-2019, 12:04 PM   #4
Fulltime family RVer
Based on the dry weight, it has a designed-in tongue weight percentage of 13.4%. Given that the layout and storage, that's likely to stay pretty consistent unless you start adding extra batteries to the tongue.
With a loaded weight of 6800 lbs., that'll give you a realistic 911 lbs. of tongue weight.
Here's the calculator I used to figure that out:
Estimating Tongue/Pin Weight from Dry Weights - Towing Planner
ependydad is online now   Reply With Quote
Old 07-30-2019, 12:19 PM   #5
Running max trailer GVWR and max 15% tongue I estimate about 200 pounds of payload left in the truck. I don't know if that's smart or not - I like to have a cushion w/ most things I do but maybe its fine.
Wheelbase wise at 145", they say the the first 110" gets you a 20' trailer and you get another 1' of trailer for every 4" of wheelbase. So my truck should be okay up to around ~29' or so. I have no intention at all whatsoever going that long, but the 2509s is 26'. Right about the limit for my 'cushion' factor.
Old 07-30-2019, 10:13 PM   #6
Before I put anything in mine, with full propane tanks and 2 batteries I was already at 700lbs on a Sherline. These things are tongue heavy. On the up side there isn't a ton of space in the pass through. My truck's payload is 1675 and my kids are small so they don't have a ton of stuff (except the car seats adding weight) and With the cooler and a couple lawn chairs in the bed along with my tool box I'm guessing we are 200lbs under payload with my stuff in the passthrough bringing the tongue weight into the 900lb range.
The cat scale at the truck stop by my house just reopened and I plan on going over them this weekend.
2019 Rockwood Mini Lite 2509S
2018 F-150 XLT FX4 Crew Cab 3.5EB 3.55
Equal-i-zer E4 hitch 1,000lb bars
2019 nights camped: 17. Miles towed: 2600.
pilotpip is offline   Reply With Quote
Old 07-31-2019, 07:03 AM   #7
2 batteries? They come standard w/ 1 right? I guess you boondock?
Why not put the cooler in the back of the trailer where the bottom bed folds up? This would lessen the tongue load and some of the truck payload?
Old 07-31-2019, 02:57 PM   #8
bikendan's Avatar
Towable batteries are a DEALER-installed item, not factory.
Most dealers will install a single cheap 12v dual purpose marine battery. If you want two batteries or a pair of 6v golf cart batteries, you have to negotiate during the buying process.
Equalizer WDH
Old 07-31-2019, 04:32 PM   #9
Rephrase - ďItís standard they come with 1 right?Ē
I know that part is on the dealer.
Old 08-02-2019, 09:24 AM   #10
If you weigh it please post how you made out.
2020 Rockwood Mini Lite 2509s
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
tongue weight, weight
