Old 07-16-2012, 12:16 PM   #1
2607 Rockwood Shower leak
I have a 2009 Rockwood 2607 Utra-lite. Has anyone had a problem with water getting in between the shower enclosure and the pan? I seal between the two, and after weight has been placed on the pan, it un- seals again. Water gets all over the bathroom floor. Any suggestions appreciated.
Arapaho52 is offline   Reply With Quote
Old 07-16-2012, 12:47 PM   #2
TURBS's Avatar
Put weight in pan then reseal while weight is in there.
Plug drain and fill to just under pan lip.
Let dry before draining.
Welcome to the forum!
Old 07-16-2012, 01:46 PM   #3
Yes. I have the same problem. The post by f1100turbo sounds like an excellent idea.
jacksum2 is offline   Reply With Quote
Old 07-16-2012, 03:27 PM   #4
lindy's Avatar
Are you sure the water is leaking between the pan and side walls? The side walls are not sealed to the pan from the factory. What's been found in the leaks is that the Aluminun framing and plastic panels are not sealed 100% and are pron to leak at the door and where the framing is sealed to the wall. Mine was like this and had the DW run the shower while I checked outside the shower and noted exactly where the leaks were
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 07-17-2012, 12:04 AM   #5
Thanks everyone for your suggestions. I will try putting weight in to the pan, and then sealing.
