07-21-2013, 12:06 AM
2703WS dinette
How the HE double hockey sticks do you configure the cushions (bolsters) to make a bed??????? There are two that have more foam in them and you can not Kay them out to make a flat bed!!! Is there a way but I can't see it? Or, is thus just a sham to say you can sleep there, thank you!!!
Rick
07-21-2013, 02:24 AM
From looking at the some pictures, it looks like the same exact dinette my new one will have..and since it's not here yet, I can't answer your question, lol. We actually discussed it last week though, and it looks like the corner cushions aren't used for the bed. I think just the three seat back cushions fit on top of the table and the corners get put aside somewhere. That's something I didn't think to check out on the floor model I looked at.
07-21-2013, 03:58 PM
Well, when yours arrives..... Or if you find out between now and then, let me know. :-) yes, the corners are not used. But when you lay the rest if the cushions flat......they are all not the same thickness. Very frustrating unless I'm doing something wrong.
07-21-2013, 04:04 PM
Hmm....I would think they would be the same thickness. The ones on my popup where, anyway. Does the table sit slightly lower than the seats when dropped down? Sounds like a pretty uncomfortable bed if it's uneven like that.
07-21-2013, 04:19 PM
I have a new Shamrock 25RS and have the same problem. The back cushions are thicker than the seat cushions. We went camping with some family members for Memorial day and I got stuck sleeping on the dinette. It was very hard because I had to sleep in basically 1 place towards the back. I was thinking of taking one of my seat cushions to an upholstery shop and give them the measurements of the table so they can make one the same thickness. I will probably leave the "new" cushion at home unless we are having company.
07-30-2013, 06:25 PM
OK....mine just got here to the dealership today and I was able to look specifically for this. Same issue. My wife pointed out that the table legs were a good 3" above the floor when set down on the rails of the dinette seats and wanted to know what would happen if I slid it under the rails and set it directly on the floor. I tried and it almost worked except that the top of the table would probably get scratched on the edges. What I'm going to do when I get it home in a few days is measure the difference in thickness of the cushions, then move the seat brackets down a little and re-screw them into the seats so that the table sits just a little bit lower when collapsed. That should take care of the problem.
07-30-2013, 06:58 PM
That is the same dinette in the 2702SS that we're looking at. I found one picture online of a dinette folded down in sleeping configuration that looked flat. Let me see if I can find it.
07-30-2013, 07:18 PM
From looking at the pics, it looks like the same one I have. I think what may have happened is Forest River started using thicker cushions and didn't modify the dinette to match. Easy fix.
08-01-2013, 12:38 PM
We just bought a 2703WS and I knew to test it out at the dealer before we bought after reading this thread. Sure enough, the cushions on the table are not flush with the others. It wasn't a big enough difference on ours that it will cause a problem, though.
08-01-2013, 02:13 PM
i have a 2014 2104s. just tried to use the dinette as a bed. had the same issue they are not the same. we ended up buying an air mattress an putting on top of it. We ended up with a 2" mattress topper and its ok. wife is thinking about making a mattress that will fit in the spot the smaller cushions go
08-01-2013, 07:44 PM
OK....just got it home today ( a few days early..couldn't wait ). Unscrewed the rails on the dinette seat that the table rests on when collapsed. Re-screwed them in a little over 5/8" lower (couldn't tell you exactly...left the tape measure in the house and was too lazy to go back and find it, so I just eyeballed it and pencil marked it then used a level to line it up ). Fixed. Cushions sit perfectly flat now.
