Old 08-14-2016, 08:19 PM   #1
ejknight's Avatar
2703WS Door Issue
I noticed last trip out that my entry door on my camper was a bit harder to close than before. on some investigation I have found that a few of the door hinge nylon washers are missing! Anyone else out there have this issue?
If so did you replace them with nylon/plastic or what?
Also how hard is it to replace them?
Ed & Kay
2015 Ram 1500 5.7 V8
2014 Rockwood 2703WS
2020 is a BUST!
ejknight is offline   Reply With Quote
Old 08-20-2016, 07:19 AM   #2
Have not had an issue like that but I did have to shim the door a bit to have tightly close and lock.
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
Martsing is offline   Reply With Quote
Old 08-20-2016, 07:27 AM   #3
SeaDog's Avatar
The washers got brittle and broke, I would replace them with the same nylon type. It is an easy job just do one screw at a time so that the door remains in position. Make sure you tighten them securely without stripping out.
Retired Navy
2016 Flagstaff 26 FKWS
door
