Old 12-05-2015, 09:31 PM   #1
2703ws Rim Replacement
I have a 2015 2703ws with 14" tires which does not give me many options on going to a high speed rating or ply. Has anyone replaced their 14" rims with 15's and successfully used 15" tires on the 2703?
bn750 is offline   Reply With Quote
Old 03-05-2016, 06:41 AM   #2
I was pondering doing this for the very same reason but not having luck finding any info on it. Came across your Dec post and wondered what you ever decided to do. We have the same year and model Rockwood as you do.
2015 Rockwood Ultra Lite 2703ws
2005 Ford F-350 Diesel
rv dunc is offline   Reply With Quote
Old 03-06-2016, 09:47 AM   #3
AKA: 'tiredTeacher
awellis3's Avatar
Who is going to do the job? You or a tire/wheel shop?
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 03-06-2016, 10:02 AM   #4
AquaMan's Avatar
While I didn't have the same trailer as you, I did change out my 14" wheels and tires, for 15" on an older Outback. The 14's had C rated tires and I was able to get 15" D rated with almost the same diameter as the 14's. Improved pulling dramatically and gained just over 1 mpg pulling it.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 03-07-2016, 04:55 AM   #5
We would take it somewhere.
Old 03-07-2016, 08:07 AM   #6
AKA: 'tiredTeacher
awellis3's Avatar
The place doing the work should be able to answer your question.
Wright and Penny
Richmond, Va.
Old 03-07-2016, 06:41 PM   #7
Sorry guy's just noticed this. I spoke with the Forest River Warranty department and was told that i could change to a 15" tire and rim as long as it's a load range C 6 ply. i am not sure why that matters. Forest River has upgraded the Dexter 3500# axles to 4000# on the 2016 model. Not sure if a D rated 8 ply tire would put too much stress on the 3500# flex axles. I have not done anything at this point but getting ready for a trip in mid march to Washington DC needless to say i am a little concerned about this.
Old 03-07-2016, 07:42 PM   #8
Not sure I understand why you think a higher rated tire would increase the stress on the axle. Stress on the axle is mainly from the weight of the trailer.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 03-07-2016, 08:08 PM   #9
I have ask them for clarification. Doesn't make sense to me either but he did say class C 6 ply was as high as i can go without voiding the warranty. I will update when i hear back from them.
Old 03-14-2016, 10:35 AM   #10
RandK-M's Avatar
When I did mine on my last trailer, I just did it myself. I just shopped online for the best price and lots of rim and tire choices. The new wheels were shipped with the new tires mounted and balanced free.
Then i just changed the wheels and sold the old ones on craigs list.
I only had a single axle trailer so I only had to order 3 new wheels and tires, but I would do it again with two axles if I needed to. Online had so many aluminum rim and tire choices for cheaper than a local shop had.
Ray
RandK-M is online now   Reply With Quote
replacement
