Old 06-09-2014, 12:26 PM   #1
2703ws television mount
I just ordered a 2703ws Emerald package from RVONE in Tampa. The dealer says it comes with a 24" TV. All the units I have seen on the lots have a 32". Has any one ever tried mounting a 37" or larger TV on the rear wall?
Rockwoodjoe is offline   Reply With Quote
Old 06-11-2014, 02:25 PM   #2
Ours came with a 32 and that's what we have in there. I would think there would be enough space to go bigger.
IndyCamp is offline   Reply With Quote
Old 06-11-2014, 07:33 PM   #3
ejknight's Avatar
2703ws Television Mount
Ours came with a 32 inch as well.
There is more than enough room for a larger TV.
Also if you replace the TV make sure the one you put in its place has a FibreOptic output and then go get a Fibre cable and run it to the Genesis 3.0 unit (you will have to remove the unit and plug the cable into the Fibre adapter on the back) for surround sound in the main room (Takes about 10 minutes of work)!
2015 Ram 1500 5.7 V8
2014 Rockwood 2703WS
Days Camped in 2016: 34 (A New Record!!)
Days Camped in 2017: 25
Days Camped in 2018 - Not Nearly Enough!
ejknight is offline   Reply With Quote
mount, television
