Old 01-28-2017, 01:16 PM   #21
gectisme's Avatar
I have two grey tanks and two separate connections.
The galley tank (kitchen) has its own drain port.
The grey for the bath sink and shower share a drain port with the black tank but there are separate valves.
Every camper is plumbed somewhat differently so they do not all drain the same.
X2, almost, our outside kitchen sink drains into one grey and the inside kitchen sink, bathroom sink and shower drain into the other grey tank. 2 separate valves, wish they were plumbed together from the factory so there was only one valve, that way we would have a lot more usable grey water storage...
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 01-28-2017, 03:51 PM   #22
CaptnJohn's Avatar
The guy that designed that plumbing never used an RV. I have 2 gray tanks, 1 for the bathroom and 1 for the kitchen. One of the items on my list always is NO outside kitchen, once was enough.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 01-28-2017, 04:58 PM   #23
Mr. Dan's Avatar
Originally Posted by chriscowles View Post
I don't have two tanks but, for those who do, are there separate drain connections? Or do all tanks drain to a single connection for the dump station? The latter seems most likely.
My trailer has 2 gray tanks and one black. There is a unique dump valve for each of the 3 tanks. There is only one dump outlet which handles all three tanks.
Old 01-28-2017, 05:34 PM   #24
Not all are like this. When we were shopping for our Mini Lite, I saw some with a gray and black that both go to one dump outlet, and then a 2nd gray that has it's own outlet. The specific one I saw had a slide stuck out in between; I knew it wasn't something I was going to like. And since one outlet was in front of the axles and the other one was behind the axles, I didn't see that they could be hard-piped together very well.
So you need to understand exactly what you are getting or have.
2011 Traverse LT, 3.6L, FWD
tank
