Old 02-12-2016, 11:47 AM   #1
3002w plumbing
Anyone know if you can access the shower plumbing on 3002w Windjammer, from under the trailer?
mrores is offline   Reply With Quote
Old 02-13-2016, 06:31 AM   #2
nomad297's Avatar
Which part of the shower plumbing are you trying to access? What are you planning in doing?
Bruce
Old 02-13-2016, 06:48 AM   #3
The O/S shower can be reached from inside,the main shower from removing the fixture from shower wall! Youroo!!
ID:	99514   Click image for larger version
ID:	99515   Click image for larger version
ID:	99516   Click image for larger version
Old 02-13-2016, 11:16 AM   #4
nomad297,
I have a leak behind the enclosure below the faucet, unfortunately it appears to be leaking from an area not accessible without removing the whole enclosure, that's why I'm asking if it can be accessed from underneath the trailer.
Old 02-14-2016, 07:45 AM   #5
nomad297's Avatar
nomad297,
Have you disconnected the faucet from the wall and looked inside of that hole yet? If not, you might get lucky and find the leak right there behind the faucet.
Bruce
Old 02-14-2016, 10:02 AM   #6
Indy Steve's Avatar
nomad297,
No, all the internal plumbing is above the floor. I thought mine was leaking at one point also, could see water running out on the floor. It turned out it was actually leaking where the shower walls met the floor. I re-caulked the whole thing including around the controls and the problem was solved. Can you see a leak when the shower isn't on?
Indy Steve is offline   Reply With Quote
Old 02-14-2016, 11:20 AM   #7
Pulled the faucet out, not leaking from there as I had hoped. The leak is coming from under the enclosure, leaks more when using the shut-off valve on the shower head.
Old 02-14-2016, 11:40 AM   #8
Indy Steve's Avatar
Assuming you pulled off the access panel at the bottom front of the enclosure? Maybe run the shower while you look under there for the leak with a flashlight? Did you turn on the faucet while you had it pulled out? I'm obviously completely guessing, but maybe the connection to the shower hose is loose coming out of the faucet? Maybe it needs some Teflon tape?
Old 02-14-2016, 12:41 PM   #9
Yes, took off access panel, leak is coming from the back of enclosure, water runs along the floor against the right side wall. Turned on faucet while it was pulled, no leak at faucet.
Old 02-14-2016, 01:27 PM   #10
If there's no leak at the faucet, I would think it would be leaking all the time if it's the plumbing, since there should be water pressure up to the faucet all the time. So if it's not the faucet, and it only leaks when showering, that would imply it's leaking from the shower stall somehow.
2011 Traverse LT, 3.6L, FWD
plumbing
