12-02-2015, 01:41 PM
#21
Splitter
As said those 30 and 20 adapters won't work if the 20 is a gfci. I got around that by using a double ended (male ) extension cord that I plug into a 20 amp receptacle that is fused to a outlet inside so that I can use an electric heater plus my fireplace, and w/h on electric. Run the fridge on propane just to be safe. The outside receptacle is a standard weather proof one from Lowes. Everything came from Lowes and have maybe $25 in everything except the extension cord which I have at least a dozen being a contractor. Yes FUSED, just like the old days.
12-02-2015, 01:43 PM
#22
Those of us who can handle wiring all use them, but double ended male cords are not for the faint hearted!
2015 335DS
12-02-2015, 01:46 PM
#23
They are called suicide cords for a reason...
There are safe, code compliant ways to provide additional power - backfeeding through an outlet isn't one of them.
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
#24
You can not count on 50A ( 30A + 20A) from a 30A pedestal. Many parks are wired in a tree configuration where 3 30A sites are protected upstream but a 100A breaker. If the two other sites sharing your 100A breaker are at 30A you might get 40A if you are lucky. If anyone on another site on your branch is doing the same thing you are doing, none of you will have power long. Every campground lists their amenities before you make your reservation, if it doesn't fit your needs go elsewhere or accept the limitations.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
12-02-2015, 01:48 PM
#25
if you notice, I never said that they were acceptable or safe OR LEGAL, but I did say that there are times that they are used anyway.
2015 335DS
12-02-2015, 02:00 PM
#26
Originally Posted by Rockwoodjoe
Where have you bought the adaptor to run a 50 amp RV on 30 amp service?
Like this one?
Available on Amazon HERE.
12-02-2015, 02:04 PM
#27
Use my 50 amp fiver all summer on a 30 amp pedestal
Our seasonal campsite on the Ohio River near Cincinnati does not have 50 amp service. I use a 50/30 adapter and we have learned to watch power consumption to not exceed 30 amps. On occasion the DW forgets to be thrifty with power and dumps the 30 amp pedestal breaker. The last few times I made her reset the breaker in hopes that there is a lesson to be learned.
I would not use the 30/20 in hopes I could get 50, our power system would not handle this very well. When 3 campers are pulling near 30 amps the voltage sags to 105 or lower. I use an autotransformer to keep my voltage above 112. The campground is old and overhead feed lines appear to be 6 gauge wire and 8 gauge near the end of the campground. The whole system is too light for modern campers.
Nick, Sharon and Finnigan
12-02-2015, 02:26 PM
#28
Who Dares, Wins
Bit OT but I thought the auto formers had their own issues of taking the available power from the neighbor's? Now potentially damaging their stuff.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
12-02-2015, 02:32 PM
#29
You can get them at Amazon.com Joe:
http://www.amazon.com/Camco-55185-Po...30+Amp+adapter
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
12-02-2015, 02:35 PM
#30
Called a Fool
Don't really appreciate that! I'm a contractor and Licensed Electrician and certainly know what's what. Been at this since '80 and just because you "think" it's unsafe, doesn't make it so. If you plug into the trailer first, which is separate from everything, you can hold right onto the "suicide end because there's nothing there. There is no "back feeding' anymore than hooking up the standard 30 amp cord.
12-02-2015, 02:55 PM
#31
Not going to get into a pissing match - but as both an electrician and an emergency responder, suicide cords hurt and kill people, and are a hack job at best.
It's not what I think, BTW - it's code...
406.6(B) Connection of Attachment Plugs. Attachment plugs
shall be installed so that their prongs, blades, or pins are not
energized unless inserted into an energized receptacle or
cord connectors. No receptacle shall be installed so as to
require the insertion of an energized attachment plug as its
source of supply.
Using a proper inlet to feed into the trailer would be a different thing altogether.
You may know it's setup to hurt people, and treat it accordingly - not everyone would...
Imagine a scenario, if you will - kid walking past trips on the cord, and pulls it out of the trailer end - kid, wanting to be helpful (and to try and hide he was cutting through someone's campsite), grabs the cord to plug it back in, and catches the live, exposed blades, and burns his hand, or worse...
a) How would you feel?
b) How fast would a lawyer be on you?
12-02-2015, 03:32 PM
#32
X2!
12-02-2015, 04:00 PM
#33
Urban legend
You can't "take" power from the system. It's all about watts consumed. Volts x Amps equals watts. At lower system voltages your current demand rises. As the system voltage rises the current demand is less.
30 amps at 100 volts = 3000 watts
25 amps at 120 volts = 3000 watts
Your rv electrics (AC, TV, etc. ) will run more efficiently at 120 to 125 volts quite possibly reducing the current requirement by a tiny amount.
The closer you can run your camper electrics to design (usually 120) voltage the lower your current draw will be.
12-02-2015, 04:34 PM
#34
I can only speak from the standpoint of having 30AMP & 50AMP sites and having campers say they need 30amp and having a 50amp RV. Our new equipment we are installing are multiplex boxes 50-30-20 AMP. They are load sensing and are designed to shut down in the event of an overload. The ones currently installed and functional will not allow a 30AMP receptacle to be dogboned or used with a splitter. This is purely a safety issue for us.
#35
Who Dares, Wins
Ok, not an electrician so sorry... But it acts as a capaciter to build up the lost power or is it a fancy device to stop your usage at 25 amps now to keep the voltage right.
2015 Chevy HD D-Max
12-02-2015, 04:38 PM
#36
Who Dares, Wins
As above, no electrician here... But if I am reading right I have seen these 30 / 20 plugs that end in a FEMALE 50 plug. I can see how they would be a suicide plug from their looks. But, if someone has one (and will admit it LOL), the two male ends musts be isolated from one another I would think??? Leg one on the 30 plug and leg two on the 20 plug, if not would they make fireworks when a hot 30amp plug is shorted into a hot 20 amp plug on another circuit? DISCLAIMER!!! I am not an electrician so be gentle...
2015 Chevy HD D-Max
12-02-2015, 04:39 PM
#37
Who Dares, Wins
So how does the box know I am using a dogbone? Do they look different than a regular box?
2015 Chevy HD D-Max
12-02-2015, 04:43 PM
#38
Georgia Rally Coordinator
Originally Posted by BamaBob
Or go to Walmart as I have bought all kinds of adapters. There. later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
12-02-2015, 05:00 PM
#39
They do look a little different. They are about 8" taller and the inside has 3 breakers and a GFCI. When we wire them in, they wire just like a 50AMP but the multiplexer is draw sensing and decides which plug to energize. It has helped our line draw tremendously. We can have 4-50's on a 200AMP master and not see any drop in source amperage at the RVs.
12-02-2015, 05:11 PM
#40
A bit a hijack. So for any further discussion on autotransformers please check the reviews of the Frank's Autotransformer in the product review forum.
If you need more info please start a specific thread.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
