Old 12-02-2015, 08:10 AM   #1
50 amp RV on a 30 amp box
How many people are running their 50 amp Motorhome at locations that offer only 30 amp service. What can be expected?
Rockwoodjoe is offline   Reply With Quote
Old 12-02-2015, 08:14 AM   #2
I run mine on 30 at the house. Only one air will run on the 30. I also have a 50 splitter I use to plug in at sites with only 30 amp. One side to 30 and the other side to the 20 amp plug with an adapter.
2011 F350 Lariat Ultimate Dually 6.7 w/ B&W Companion
2014 Heritage Glen 356QBQ
2016 Explorer Platinum, 1998 Mustang
1SG(Ret) (1987) US Army Aviation
Days/Nights Camped 2016: 34
dogwood36322 is offline   Reply With Quote
Old 12-02-2015, 08:55 AM   #3
bubbles's Avatar
You can expect 30 amps to be available. The shore power pedestal CB will trip if you exceed the limit (hopefully). I only stay at places that only offer 30 amps if the AC's are not needed, otherwise I pass.
Old 12-02-2015, 09:05 AM   #4
Camper John's Avatar
As a park owner I want to caution RV owners about using these splitters to connect 50AMP units to 30AMP site electric. I get told all the time that if a problem exists it has to be in the park system. I have 2 examples of why this is not always the case. 1 is the buzz bar we have one the office counter with the notice that NO adapters are permitted. The other are photos of the 40' HR MH that burned to the ground 2 years ago. After the insurance company and the State Fire Marshall investigated both concluded that the fire was caused by an overload of coach shore power system. I hear too many time that the park is "just trying to gouge campers by charging extra for 50AMP" and that is why campers use these magical adapters. Personally I won't risk losing my 5'r over a $5 @ day upcharge for 50AMP.
Camper John is offline   Reply With Quote
Old 12-02-2015, 11:20 AM   #5
30 amp works fine. Just have to work with that power budget. Turn off electric hot water. Limit to one AC. Watch high power devices like microwave hair dryer toaster and heater. Limit to one at a time if AC on
Harkerr is offline   Reply With Quote
Old 12-02-2015, 11:32 AM   #6
BMac
Along the same thread, I plug my 30 amp into a 50 amp outlet with an adapter because the 30 amp outlet in my tower is loose. Am I only getting 25 amps to my trailer?
bbbymac is offline   Reply With Quote
Old 12-02-2015, 11:38 AM   #7
Frankly, when it comes to Georgetown, they wire all of their coaches with 50 AMPs. From a manufacturing standpoint it makes it much easier than stocking 30 and 50 amp cables, panels, etc. I only have one AC unit and, although it is 15000 BTU, it is rated at something like 16 amps. Add in the water heater (10 amps) OR the microwave (9 amps) and you are up to the high 20's. You can't run everything at the same time and it's safest to run the water heater on propane if you are using air conditioning. Otherwise...you will never have a problem with a 50 to 30 amp adapter.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 12-02-2015, 11:42 AM   #8
Who Dares, Wins
doc73's Avatar
No you get 30amps. Box will give 50 but your trailer will / can only pull the 30 before (hopefully) somethings trips.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 12-02-2015, 11:43 AM   #9
Where have you bought the adaptor to run a 50 amp RV on 30 amp service?
Old 12-02-2015, 11:49 AM   #10
Blog: RVroadtripper.com
hbillsmith's Avatar
Which are you speaking about?
- the 50amp to 30+20 adapters that plug into BOTH the 30amp and the 20amp with the expectation that the power stand will provide 50amps? The don't work on GFI receptacles I believe.
- the dogbones that simply feed the parks 30amp into one leg of the 50amp?
I can't see how one can travel without a dogbone. I use one but restrict my trailer usage to stay under (i.e. only use one of these at a time -A/C -Microwave -hairdryer). Any two, including using 2 A/C's will go over and pop the breaker. But if you are diligent, it lets us 50ampers stay in parks that do not offer 50.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
50 amp
