Originally Posted by Zoom
What most don't realize is with a 50 amp connection you actually have 100 total amps available. If you use a 30 to 50 adapter you will have only 30 total amps split between two 50 amp connections. If you use the adapter that has the 30 and 15 amp connections you will get 45 total amps only if the campground has not just pulled the 15 amp breaker connection at the ped off of the 30 amp circuit feed. Most campgrounds will power multiple sites from one common feed so the 45 amp will work if all campers at the site is not pulling maximum current.
Originally Posted by Kimber45
If you only have a 30 amp camper a 50 amp site would be pointless i believe. I have my first 50 amp unit on order and am used to 30 amp rv's. Must spots I camp only have 30 amp service so I will be going the other way and hoping it is never hot enough to need both air's.
Originally Posted by rockfordroo
I believe if you have a 50 to 30 amp adapter, you will get 30 amps from ONE of the two 50 amp circuits. Since your 30 amp is only a single circuit, it cannot be set up to split between the two 50 amp circuits, or you would be "shorting them together."
Most adapters use one side or the other of the 50 amp circuits; although I believe someone makes one that allows you to chose which one you use.
Originally Posted by bubbles
With a 50 (male) to 30 (female) you will get 50 amps to the single RV 30 amp buss. As said a 30 (male) to 50 (female) will get you 30 amps (total) to both 50 amp RV busses.
I
think we're in violent agreement here, if you're intent was to make everything clearer with the male/female. The original quote was "50 to 30" which at least to
me (not owning a 50 amp TT) means 50 at the pedestal and 30 at the camper (i.e., 50 male, 30 female), especially given that the original post related to plugging into the 50 amp outlet at the pedestal. So I stand by my statement that 50 to 30 doesn't split the 50 amp circuits.
30 to 50 will connect both of the TT's 50 amp circuits to the same 30 amp supply, and will be limited to 30 amps total (by the pedestal's 30 amp breaker).
WMTire's post #14 explains all this the best.
But adding male/female certainly makes it very clear which direction you're talking about..
