Old 05-08-2015, 10:28 AM   #11
TGR
TGR's Avatar
I've stayed at several campsites that had only a single 50 A service and a 20 A service on the pedestal. A pigtail will ensure your hookup should only 50 A sites be available.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
Old 05-09-2015, 11:41 AM   #12
Originally Posted by elind View Post
Boy, that looks dumb unless your sharing the box with two camp sites.
That is why I take Pics. You cant make this S--- up! Pics or it Didnt Happen! Youroo!!
Old 05-09-2015, 02:35 PM   #13
Phat Phrog Stunt Crew
elind's Avatar
I know about pics and dumpster divers!!!
elind is offline   Reply With Quote
Old 05-12-2015, 02:16 PM   #14
wicked1's Avatar
Originally Posted by mr dually View Post
Usually there will be a 30amp plug right next to the 50 Amp as well as a 15/20amp.
I have never seen a 50 amp only but if that's the case you can use an adapter. I carry one just in case the 30 amp plug is IFFY.
X2 I carry a 30 and 15 as well as 100 ft of heavy duty electrical cord just in case
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 06-22-2015, 11:37 PM   #15
Chuckinca's Avatar
Those duplex boxes are very common.
Can be used by either 50A or 30A rigs.
2018 Flagstaff 29KSWS
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
Chuckinca is offline   Reply With Quote
Old 06-23-2015, 12:02 AM   #16
wmtire's Avatar
Originally Posted by RSchleder View Post
As long as you understand you'll have 40% less amperage capacity, all will be well.
RSchleder, in actuality a 50 amp service is a 50 amp 120/240 volt split phase service. What this means is you have TWO legs of 120 volt power, EACH at 50 amps, for a total of 100 amps. So you have a lot bigger difference than just 50 to 30. This is often times confusing.
If you will notice in the pic below, a 50 amp service has a double pole breaker, that controls TWO 50 amp legs....while a 30 amp service has a single pole breaker controlling ONE 30 amp leg.
A 30 amp service at 120 volts = 3600 watts
A 50 amp service at 120 volts = 12000 watts ( 2 legs at 6000 watts each)
Better reading below than my probable more confusing explanation:
AC Electricity
RV Electric
Electrical Tutorial - Chapter 3 - 30 Amp versus 50 Amp
RV Electrical Systems
Name:	50amp outlet (Medium).jpg
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
50 amp, service
