Old 05-07-2015, 08:06 PM   #1
keeprr's Avatar
50 Amp Service
Our Mini Lite operates on 30 Amp AC. When campgrounds and/or National Parks show 50 Amp, do they have a 30 Amp on the same post? If not, do I need a special adapter or just a 50 to 30 pigyail?
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
keeprr is offline   Reply With Quote
Old 05-07-2015, 08:14 PM   #2
50 to 30! Youroo!!
Old 05-07-2015, 08:14 PM   #3
mr dually's Avatar
Usually there will be a 30amp plug right next to the 50 Amp as well as a 15/20amp.
I have never seen a 50 amp only but if that's the case you can use an adapter. I carry one just in case the 30 amp plug is IFFY.
03 Fleetwood 31g LS
06 Chevy Gas Dually
07 Yamaha golf cart
Looking to purchase a Georgetown 364 ts Mh in the next couple of years.
mr dually is offline   Reply With Quote
Old 05-07-2015, 08:16 PM   #4
RSchleder's Avatar
Many/most RV electrical posts that have 50A, also have a 30A receptacle. If not, no big deal, simply use the 50A to 30A pig tail and everything will work fine. Just be aware that you will only have a max total of 30 Amps instead of your normal 50 Amps. You will only be able to run ONE a/c unit for example. As long as you understand you'll have 40% less amperage capacity, all will be well. If you load things (use electricity) at a rate of more than the 30 Amps, you'll simply trip the breaker on the rv park post to the one in your "breaker box". No big deal, reset and unplug something and you'll be fine!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-07-2015, 08:19 PM   #5
These were in a BIG C/G in Wis? Youroo!! You never know!
ID:	76400   Click image for larger version
Old 05-08-2015, 08:13 AM   #6
keeprr's Avatar
Thanks. We just got back into camping after 37 years. Back east the marinas are set up with 50 and 30 on each post and I was hoping campgrounds were mostly the same as I still have various adapter configurations.
Old 05-08-2015, 08:19 AM   #7
Have seen a couple with 50A only, one in Astor, FL and C section in Thousand Trails Mocksville, NC. 50-30 adaptor solves the problem.
Old 05-08-2015, 08:40 AM   #8
5er_tom's Avatar
Twice I needed the 50 to 30 converter. They are not that expensive and a good piece of insurance.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 05-08-2015, 08:59 AM   #9
Phat Phrog Stunt Crew
elind's Avatar
Boy, that looks dumb unless your sharing the box with two camp sites.
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 05-08-2015, 09:06 AM   #10
Since OP's trailer is only 30A, it shouldn't be a problem.
X2
Should be between $15 - $20. More if you go to an actual camping store.
Iwritecode is offline   Reply With Quote
50 amp, service
