07-29-2016, 12:13 PM
50 amp versus 30 amp
Hopefully this won't be a "real" dumb question. We recently purchased a Rockwood 8328BS with 2 a/c's and 50 amp service. If we are staying where only 30 amp is available can we still run everything, including both a/c's or will we need to run 1 a/c at a time all the while keeping the water heater on gas and not electric.
Thanks in advance!
07-29-2016, 01:55 PM
You will only be able to run 1 a/c. Some say you can do both and nothing else, but with the questionable quality of campground electrical pedistals, I highly advise against it.
"Do or do not, there is no try" - Yoda
"Do, or do not, there is no try." - Yoda
2017 Cherokee 294BH
2015 Ram 2500 4x4 6.4L V8 Crew Cab
07-29-2016, 02:04 PM
Only one A/C and be mindful of what else. (depending on what all you are trying to power up)
07-29-2016, 02:05 PM
1 A/C and you will probably have to shut that down to use microwave
07-29-2016, 02:28 PM
If you’re limited to 30 amps use one A/C and be sure to use your water heater on propane. You shouldn’t have any problems using the microwave and other appliances. Just watch how many you use simultaneously.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
07-29-2016, 02:46 PM
Only one AC, like other have said, but you should have no problems with running anything else. My other unit had 30 amp and could run 15k AC, wh, refer, and microwave with no issues.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
07-30-2016, 12:10 PM
As said, 1 a/c and don't run your electric water heater. See attached Amp chart.
07-30-2016, 12:33 PM
-R.Jones
Nitro 31FQSL
R. Jones speaks for me. When we have our 50a Wildcat on 30a, we run 1 A/C at a time but don't change any other thing... meaning we leave water heater on electricity and use the μ-wave whenever we want.
07-30-2016, 12:50 PM
Same thing with my new 50 amp XLR on 30 amp service too
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
07-30-2016, 06:01 PM
Thanks to TomRobb1161 for posting current draw for various appliances and devices. Those are helpful. I think that on the load list, the 12k btu AC (about 3,500 watt) is listed as drawing 15 amps.
However, I am thinking that 15 amps would be the correct load draw at 220v, but that at 120v the draw would be 30 amps for a 12K btu unit, and about 37 amps for a 15k btu (about 4,400 watt) unit.
Our Wildwood TL is equipped with a 12k btu unit, so we have (2) 2000 watt generator/inverters capable of operating in tandem to adequately and safely provide the 3,500 watts we need for our AC and other loads. These two generator/inverters are quiet and light, only about 43# apiece. These are the Yamaha EF2000iSv2 which provide pure sine wave current and voltage, the equivalent quality of commercial power.
07-30-2016, 06:11 PM
My 15kbtu draws about 15 amps starting and 8 running.
07-30-2016, 06:30 PM
Thanks in advance!
I'm guessing, based on a trip to Canada that we recently completed. Most of the CGs that we stayed in had only 30 amp service. Run only one a/c at a time, but you can leave your water heater on electric and you should be fine.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.” ― Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
07-30-2016, 06:58 PM
Nothing in most any RV is set up for 220/240 volts. They do make some stuff on higher end models (usually clothes dryers) that use it, but it's the exception not the rule. You A/C's are going to be 120 volt. You'll probably also notice if you open up your RV's electric distribution panel inside the RV, that the AC's are on dedicated 120 volt single pole 20 amp breakers.
This formula may help in figuring out what you can use. Usually, members with 30 amp RV's already are aware of what they can run at the same time (and what must be turned off) in order to not trip circuit breakers. It's called selective use.
Watts = voltage X amps
or amps = watts/volts
EX : 15 amps = 1800 watts/120 volts
Also these links may help better explain exactly what a 50 amp 120/240 volt split phase RV service is, as many people don't fully understand how it works in relation to RV's.....and how it is all 120 volts. Many people don't realize that a 50 amp 120/240 volt split phase service is capable of providing a total of 100 amps of 120 volt power. It's all part of the learning curve.
Electrical Tutorial - Chapter 3 - 30 Amp versus 50 Amp
AC Electricity
RV Electric
2011 Flagstaff 831 RLBSS
07-30-2016, 07:04 PM
Georgia Rally Coordinator
-R.Jones
Nitro 31FQSL
X 2 Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
07-30-2016, 07:13 PM
I fired mine up on 30A this week just to see how it would perform before I hooked back up to 50A. I ran both AC's ( one 15K and one 13.5K ) and nothing else for about half an hour. My EMS read 27A @ 110V for nearly the whole time. So....yes, it is definitely doable, but I'd recommend an EMS to keep the voltage from dropping too far.
07-30-2016, 11:19 PM
It's really amazing how these RV'ers can run an A/C, 15 amps, microwave, 12.8 amps, electric water heater, 12.5 amps - total 40.3 amps on a 30 amp circuit, plus all the other parasite draws without any problems.
07-31-2016, 07:33 AM
Don't forget you can also turn your refigerator to gas also
07-31-2016, 07:52 AM
World Wide Wanderer
I figure it must be some kind of new math...
I KNOW for a fact that with my fridge, converter and A/C going the microwave WILL trip the circuit. So we just turn the A/C off when we want to use the microwave. I usually brew my coffee outside on a separate 20 amp cord.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
07-31-2016, 08:27 AM
Aaron
Must be a miracle but I never had a problem
Keep in mind the wh doesn't constantly draw max amps. Once heated up the amp draw is trimmed back just to maintain temp. I suspect the same is true for refer.
Guess I've had two miracle trailers with no issues.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
07-31-2016, 08:40 AM
Aaron
My report is not based on math of any kind... new or old. My report is based on observable fact. I have never tripped a breaker, inside or out, when running my 50a trailer on 30a. I never turn on the propane side of my water heater. I never run the fridge on propane except when on the road. Adding the total amp draw of these appliances proves little since, as Jones implied, all these units seldom run full draw simultaneously.
