Old 10-06-2013, 09:43 PM   #21
Ford Idaho's Avatar
Originally Posted by OldCoot View Post
If you use the Reese Revolution Hitch and activate it by installing the wedge at the rear of the hitch pin, you don't need or want a disc at the hitch pin. The hitch pin does not rotate at the hitch. The trailer pivots 22" behind the hitch pin at the trailer pivot.
I have a Pullrite 16k.
Old 10-06-2013, 09:47 PM   #22
phat phrog stunt crew
as others have said, get level as possible, chock wheels and back under trailer to get kingpin off the jaws. should come open easily then.
dwaynerz is offline   Reply With Quote
Old 10-07-2013, 01:16 PM   #23
dcheatwood's Avatar
I asked Reese about lube plate. They confirm what you (old coot) and I have been say in. Here's the reply.
"If you use the Reese Revolution Hitch and activate it by installing the wedge at the rear of the hitch pin, you don't need or want a disc at the hitch pin. The hitch pin does not rotate at the hitch. The trailer pivots 22" behind the hitch pin at the trailer pivot."
TechSupport@cequentgroup.com
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
5th wheel, hitch, wheel
