Old 04-06-2017, 06:11 PM   #1
5th Wheel Level
I was wondering if there is a specific Level that works best on a Revolution 5th Wheel Hitch. I purchased a Level Master #6780 and it is to big to mount on the hitch. The Revolution is only 10" wide. This is my 1st 5th wheel so not sure if mounting a level to the hitch is the best thing either. Thanks for the help.
david s is offline   Reply With Quote
Old 04-06-2017, 06:26 PM   #2
Jim34RL's Avatar
What model of 5TH wheel do you have? Do you have the 6 point auto level on your trailer?
I do not have any leveling device on my hitch or trailer since I have the 6 point level up system. This levels the trailer within 1/10 of an inch. I do check the fridge to make sure it is level with a torpedo level.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 04-06-2017, 06:30 PM   #3
I have Rockwood 2720 WS. I do not have the auto level feature.
Old 04-06-2017, 06:49 PM   #4
I don't have a Rock,but I mounted my level on the front under the over hang. Just to where I could see it out of my drivers side mirror.Just level the camper and mount the gauge.
2011 Ram Mega Cab 3500 Larimie dually
2016 Chaparral 370FL
DaveandSue is offline   Reply With Quote
Old 04-06-2017, 06:56 PM   #5
Thank you
Old 04-08-2017, 01:04 PM   #6
Four foot level on the floor.
rat4spd is offline   Reply With Quote
Old 04-08-2017, 03:34 PM   #7
Thank you
Old 04-10-2017, 07:39 AM   #8
jtatum65's Avatar
I have the same level and the same 10" wide revolution. What I did was reverse the mounting brackets. This will make your level appear to have ears, but you can cut the overhang of the bracket off if you don't like the appears. I just left mine alone. I will try and post pictures if you would like.
Jim & Evelyn Tatum
2023 Columbus River Ranch 391MK
2022 Dodge Ram 3500 Big Horn Diesel
Nights Camped 2023 = 30
Nights Camped 2022 = 40
jtatum65 is offline   Reply With Quote
Old 04-10-2017, 12:37 PM   #9
Thanks I will give that a try
Old 04-10-2017, 02:43 PM   #10
I have the same trailer would like to know your solution. Keep us posted.
jhcriscuolo is offline   Reply With Quote
Old 04-10-2017, 07:17 PM   #11
Will do
5th wheel, wheel
