Old 03-20-2016, 06:07 PM   #11
Location: Santa Rosa CA building home in Plumas Lake, CA
Originally Posted by Big earl View Post
Can you move the pin box down on the trailer
Thats a good question. When it stops raining I will go find out. hadn't thought of that. Thanks
I am thinking I would have to raise the hitch to the next hole to give me more clearance then raise the pin to allow the nose to drop and I may be back where i started. I dont really want to raise the hitch because that whould interfer with the bed cover when not pulling.
2014 Ram CID 4x4 long bed
2013 FR Rockwood 8281 w/Revolution pin
Sam (me) Diane (DW)
Sofie and Phoebe (fur Babies)
historybuff is offline   Reply With Quote
Old 03-24-2016, 07:47 PM   #12
MikeInRaleigh's Avatar
Lifting 5th wheel
I fretted a lot about this a couple of years ago when I moved from a Silverado 1500 to an F350. I even calculated the additional weight being carried by the rear axle due to the trailer out of level, and verified it at a scale. Even then, I was still within the specs for both tires and axle. I had a good opportunity to change the start angle on the axles last fall when I lost a bearing and had to replace one of the axles. However, it was going to cost me another $1000 to replace the second axle. I've never had any issues with towing, so I just decided to live with it. I did upgrade the tires to Load Range D to give a little more margin on the real axle, and I have about 6" clearance to the bed rails, so clearance is not a problem for me. By the way, if you do decide to change out the axles, I had great support from Axleinc, in Elkhart in getting a replacement axle.
2010 Rockwood 8280WS Fifth Wheel
2013 F350 Crew Cab SRW, Standard Bed PS Diesel
Reese Airborne Pin Box, Reese 16K Manual Slider.
Camped 36 Days in 2012, 23 Days in 2013, 35 Days in 2014, 30 Days in 2015, 46 Days in 2016, 5 days in 2017.
MikeInRaleigh is offline   Reply With Quote
Old 03-24-2016, 07:50 PM   #13
Lifting 5th wheel
I didn't mention that I am 3 to 4 inches out of level when hitched.
Old 03-25-2016, 09:22 AM   #14
mstell2's Avatar
I ordered the lift kit from forest river for my 8281 and it made a world of difference. I put it in myself in one day. Now I pull level.
mstell2 is offline   Reply With Quote
Old 03-25-2016, 09:30 AM   #15
Left Coast
Remember when measuring from back to front for level, say 4" out of level, you only have to lower. or raise, 1/2 that distance as the tires are the pivot point
Sent from my XT1080 using Tapatalk
Old 03-25-2016, 09:42 AM   #16
W5CI's Avatar
I would be more concerned about my over all height than being level while towing. I am right at 13'6" now and any raising would not work to well
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is offline   Reply With Quote
Old 03-25-2016, 09:43 AM   #17
DaveSchwartz's Avatar
Originally Posted by historybuff View Post
the hubs may have some adjustment for the start angle. Or as earlier stated I may have to change axles to get the correct angle.
They don't (have any user-adjustability, that is).
Here's some research I did when this topic came up last year.
The start angle is set by the way the square hole is cut on the axle-end of the spindle arm and then its permanently welded on. The start angle is indicated by the axle part number so you could buy new axles with a different start angle.
The lift kit that Dexter sells is probably by far the better option.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 03-25-2016, 09:47 AM   #18
Left Coast
Rear axle carring more weight...
Old 03-25-2016, 10:06 AM   #19
B and B's Avatar
I had a lift kit installed at the Goshen rally. Tow level was number one reason, Second reason upon checking with thermometer rear tires and hubs they were taking more load. Third benefit is close to 8 inches truck bed to trailer clearance with the Superduty, the F 150 had 6 inches.
Dexter makes a kit that is engineering for the job, comes complete.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 03-25-2016, 05:52 PM   #20
After spending the last couple days trying to wade through Turbo Tax I am back on the axle project. Looks like it could be an easy install. I wont do it myself but I dont see it being over about three hours in an axle shop. I will definantly give forest River a shout Monday and see what they have. Thanks for all the good ideas on this subject. I will post what I find at FR
Sam (me) Diane (DW)
5th wheel, wheel
