Old 11-26-2013, 10:09 PM   #21
gbpenn's Avatar
Thanks for the info. Having read your earlier posts I was watching out of r the carpet issues. Our shakedown trip turned out pretty successful . We only had two problems(knock on wood) both of which I was able to fix at the campground.
We went to Anza Borrego desert which was prety cold (to us) at about 38 F at night and 85 F during the day. The first problem was with the heater ducts. the center duct in the living area was not putting out any air at all. I went into the front storage area on the ODS side and took down the wall piece there and sure enough one of the vent tubes was split in half. After cutting and reattaching every thig worked fine.
The second problem had to do with the TV. It would not detect any channels after scanning. I found a disconnected cable behind the TV. Reconnected this and eveything worked fine.
I took not of your incident with the table turning over on you. When we dir the PDI I noticed two holes in the floor just under the edge of the couch. When I asked the service guy said these were supposed to be hooks for securing the table during trapsport. So I had them install the hooks and provide straps. We now strap down the table and put a bunch of pillows betqween the table and the sides during movement.
Other than those two problems, everything worked well and we very much enjoyed the space and the movable table. It served as an extension of the kitchen counter when cooking, an eating area we could put anywhere we wanted, and with both sides down a general surface area for sitting anything you want. We moved the towel holder from behind the toilet to on the sliding door. This makes much more sense in our opinion. Still struggling with where to put the toilet paper holder though.
All in all we are VERY pleaswed with the unit. It is everything we envisioned and more, and it tows like a dream.
Next trip to Solvang, CA. for New Years.
gbpenn is offline   Reply With Quote
Old 11-26-2013, 10:11 PM   #22
gbpenn's Avatar
Sorry for the grammer and spelling errors, we just returned home.
Old 11-27-2013, 04:52 AM   #23
dcheatwood's Avatar
Knew you'd love the tow. I also moved the towel holder to the door. Wife bought a small metal free standing toilet tissue holder and puts it in the corner between bathroom door and towel cabinet door. I wanted to mount the roller inside the cabinet so that it swung into the top of lower compartment. we'll see. Any trouble with television latch?
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 11-27-2013, 06:24 AM   #24
French's Avatar
Grey tanks
Hi guys
Sounds like you are enjoying the 8282 for the most part. Question for you... Some on here have mentioned the small grey tank capacity on the 8282 as a "knockout" or reason to eliminate the 8282 and chose instead the 8280 or other.
Is the small capacity an issue. We are still heavily leaning towards the 8282 but the weight police and the grey tank issue has us concerned. We looked at the 8280 and could live with it ... Less pin weight, less total weight, double grey tank capacity of 8282.... But the opposing slides and the open seating area the tv and desk configuration draws us back to the 8282
Any thoughts?
Dave and Joanne
Southwestern Ontario
2016 Ford F250 Lariat crew cab 6.7 diesel
2015 Rockwood 8285IKWS Diamond
Jokes about German sausage are the wurst
French is offline   Reply With Quote
Old 11-27-2013, 07:03 AM   #25
dcheatwood's Avatar
French, I went from a wildcat 5er with 2-50 gal gray tanks to the 8282 with 1-38 gal gray. Had concerns. So far it has not been an issue. Just me and wife and we usually have hookups. I did buy (traded for) a portable tank just in case we dry camp for any length of time. Its sad the tanks are so small but so far we've managed ok. Really enjoy the big room with fireplace and TV facing the theater seating. Good surround sound too. Good luck.
Old 11-27-2013, 07:39 AM   #26
French's Avatar
8282
Thanks for the quick reply Dave, we appreciate the heads up on the island and floor issues as well. Camping season is over here in Ontario. The temperature has not been above freezing in days. We are thinking of waiting for the winter rv shows in Toronto to see what kind of deal we can get on a 8282 WS. Are there any options or add ons you wish you had ordered now that you have experience with your rig? We have a firm price of 38k on a 2014 8282 diamond a local dealer has in stock. Camping season starts here in April so we are not in a hurry to purchase and then store a rig....Any other thoughts or suggestions are most appreciated
Dave and Joanne
Old 11-27-2013, 07:55 AM   #27
JoeMazz's Avatar
We installed ours inside the cabinet on the door. Out of site and is right where you want it when you need it...
2015 Jayco Precept 35UP
JoeMazz is offline   Reply With Quote
Old 11-27-2013, 08:40 AM   #28
JoeMazz's Avatar
Originally Posted by French View Post
Hi guys
Any thoughts?
It's a tough call, I know. I went through the exact same thing. The grey water tank was never an issue for me, as I will never dry camp. It was always about the weight.
In the end, I decided that the extra 138 lb. pin weight difference wasn't enough to deter me from choosing the floor plan I like best. Would the 8280 work; absolutely, it's a solid floor plan copied by almost every RV manufacturer.
The rolling table in the 8282 I could take or leave (it can be a nuisance and there is more than enough cabinet space in the kitchen) but the large living area is without question the most redeeming feature, and ultimately the reason we upgraded to it from the TT.
Good Luck with your purchase...
Old 11-27-2013, 09:39 AM   #29
BamaBob's Avatar
Hmmm this sounds like a great idea! DW and I have been puzzling over where to install the TP holder
As for a towel rack, we already had this over the door 3 tier towel rack we used in Germany (German bathrooms are floor to ceiling tile and landlords do NOT like you to mount things on the walls ) It works great and I have seen similar towel racks in Target & Wally World.
Shower Mod: we got a suction cup hook from Bed, Bath & Beyond - it actually has a "pump" in the center than maintains suction. Put that on the left side of the garden shower and got this very lightweight 3 teir plastic shower rack that holds all the soaps/stuff you need in the shower. All seems more than sturdy enough to leave in place when on the road (guess we will find out in time )
Does the 8282WS have the cool laundry chute feature in the bathroom cabinet? If so, there is a collapsable laundry bag with handles at Wally World that fits *perfectly* under the chute and is large/long enough to actually hold a basket full of towels/clothes! I attached a couple of clips to the floor under the chute and the laundry basket "handles" clip to these to secure the laundry bag to the chute.
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 11-27-2013, 09:48 AM   #30
JoeMazz's Avatar
Yes we use the chute all the time. I'll have to look for that next trip to Wally World.
