"over that time the battery slowly discharged to zero." What were you using to measure the battery voltage with. Herk7769 is correct, but I'm wondering if you had a voltmeter that read "0'" volts, or were using the monitor panel. By the way, every time you use the monitor panel it takes current from the battery. If you had a voltmeter really showing zero volts, you have a problem that needs correcting. And now is a good time while in storage.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
