01-22-2011, 11:53 AM
8285sw Questions
We are considering buying a Rockwood Signature Ultra Light 5th Wheel Model 8285SW. I have a few questions, which I am hoping some more experienced Rockwood owners can answer. We previousily owned a Sportsman 5th wheel so are not new to this. We can't find this camper locally, so can't get my questions answered.
1. This camper is listed as having a 76 gallon gray water tank. Is this one large tank with one cleanout or two tanks with two cleanouts? I don't want to have to battle this at the dump station.
2. I don't see anything about a spare tire, but am assuming one comes as standard equipment. Is this true?
3. Because the roof ladder is an option, I am wondering if it is okay to walk on the roof? I know on some campers, the roof is not strong enough to support your weight.
4. My tow vehicle is a Ford 2001 F-250 V10 SD extended cab Gas 2-wheel drive with short bed. Is anybody pulling this camper with this tv or something similiar to it? I would welcome any and all comments about towing.
01-24-2011, 06:31 PM
Originally Posted by mvsu002
First of all, welcome to the forums. We have a 8280WS but for your questions, it won't matter.
It will have 2 - 38 gallon tanks...one located under the basement area with a common sewer hook-up with the black tank. The 2nd tank is for the galley and would be located behind the camper's axles with it's own, separate sewer hook-up.
The spare tire and cover are part of the convenience package which is a mandatory option (oxymoron!)
The roof is plenty strong enough...I frequently go up there to check the general condition of the roof and caulking. No clog dancing up there, however!
You'll won't have any issues towing the 8285WS with your TV. The pin weight is listed at 1187 lbs...will probably be in the 1500 lb area when loaded. Perhaps some 8285WS owners will respond also.
Good Luck with your choice.
Dave
01-28-2011, 11:21 AM
Dave,
Thanks for the information. I wish Forest River would come up with some way to connect the 2 gray water tanks, so you only have one drain. How do you handle this at the dump station? Do you dump the aft tank first then pull ahead and dump the front tanks?
01-28-2011, 01:44 PM
I have 2 10ft. and one 5 ft. drain hose. This gives me 25 ft. I have not had a problem at a dump station.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
01-28-2011, 04:20 PM
You can also purchase a "y" connector to attach hoses from both dump connections together, then all you have to do is pull and close all the handles.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
01-30-2011, 03:08 PM
Hi and congrats on your new 8285WS. I think you wrote 8285SW
Yes it has 2 tanks. One for galley and one for the show/sink. Two different locations and not hooked up together. I think they may have done this because of weight distribution.
As far as I know the spare tire and carrier was a seperate option but may be included in a particular package.
As far as I know the ladder was a seperate option but may be included in a particular package.
You will not have any problem with your F-250 V10 puling this 5th wheel.
Ask more questions or you can see me at the Forest River Owners Group Rally in Branson MO on May 1-4, 2011 (see below)
