Old 08-27-2011, 02:26 PM   #1
Jimcam22's Avatar
8285WS Slide Problem
I have a 2011 8285WS and I'm having intermittent problems with the big slide. When I bring it in it won't go out, it just clicks like the gears are not engaging. I had it worked on several times and they loosen the bell stop and readjust it and send me on my way only to have it fail again after some time. I had the motor replaced and that was supposed to be the fix but it wasn't. The slide still sticks in the in position occasionally. I checked the bolts holding the motor and they are tight. I am thinking that the slide may be misaligned.
Any thoughts??
Thanks,
Jim
2011 Rockwood 8285WS
2012 F150 SuperCrew Ecoboost HD payload
Curt 20K Q5 Slider Hitch
Jimcam22 is offline   Reply With Quote
Old 08-27-2011, 02:37 PM   #2
Jimcam22's Avatar
I just checked under my slide and this is what I found. The first picture is a shot of the bell stop with the slide all the way in. The bell stop has about a 1/4 inch gap at the top. Does this indicate an alignment problem.
The second picture is a shot of the place the bell stop seats with the slide all of the way out.
If anyone has an 8285WS and could check theirs I would greatly appreciate it..
Thanks,
Jim
ID:	7622   Click image for larger version
Old 08-27-2011, 06:06 PM   #3
Hoo Dad's Avatar
I'll try and check mine for you tomorrow. I'm on the east coast (thankfully not right on the coast) so you can imagine I will need to wait until Irene gets out of here.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 08-27-2011, 09:03 PM   #4
Jimcam22's Avatar
Thanks Hoo Dad. Stay safe...
Old 08-28-2011, 12:22 AM   #5
Nigels's Avatar
Your second photo of the slide out looks identical to mine when I saw this I also thought it might be misaligned. Mine also looks as though it grinds against the frame but it does not. I have no problems with the slide, not sure what the tube looks like in, I will have a look tomorow.
Sounds like something is getting stuck maybe the floor, the sound of gear crunching is apparantly the clutch and makes this sound at the end of each in or out to warn you to gret your finger off the switch.
Nigel & Bev
Brit Driver & Canadian Naviguesser
2011 Rockwood Signature Ultra Lite 8280ws
2011 Dodge Ram 3500 4x4 Diesel
Nigels is offline   Reply With Quote
Old 08-28-2011, 08:28 AM   #6
Hoo Dad's Avatar
I checked mine with the slide in and it looks just like yours. I ran the slide out with the same result (it looked just like yours). When the slide is retracted IN does the slide appear to be flush against the camper at the front and rear of the slide?
I would call Forest River Monday and explain the situation to their service people. They may have an answer.
Good Luck
Old 08-28-2011, 08:52 AM   #7
Jimcam22's Avatar
The slide appears to be flush front and back when it is pulled in, When it comes all the way in it makes a clunk sound and stops. When it goes out it makes a clicking sound at the end of travel until I take my finger off the switch.
I'm thinking I may have another bad motor assembly. Jamming when fully retracted..
Old 08-28-2011, 08:59 AM   #8
Herk7769's Avatar
This is totally normal. The clunking sound is the nylon drive gears "hopping" on the rack teeth at end of travel in and out. This noise should remind you to get your finger off the switch.
HAM CALLSIGN - KC3FFW
Old 08-30-2011, 07:27 PM   #9
DAISY BOYKIN's Avatar
Yap, been done that !
yes mine is the same way, I think it is normal. I did re adjust the "bell stop" . The jam nut came loose on mine. Read the specs for the slide out to adjust the jam nut.
I think you are a-ok.
Sid
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 08-31-2011, 10:32 AM   #10
Jimcam22's Avatar
Thanks for all of the replies. I call my dealer and spoke to one of the service people and he told me how to adjust the bell stop. It seems to be working OK now. We'll see for sure the next time we travel.
