Old 06-04-2014, 08:37 AM   #1
TigerPride
cajunrvr's Avatar
8286ws water heater question
This is only the second time we have camped in our 5er and no matter if you put the water heater on gas r electric the water is only luke warm at best with hot knob on and cold knob off. any suggestions. All info would be helpful
cajunrvr is offline   Reply With Quote
Old 06-04-2014, 08:43 AM   #2
Check your hot water heater by pass, sounds like it could be open.
darkcloud is offline   Reply With Quote
Old 06-04-2014, 08:44 AM   #3
TigerPride
cajunrvr's Avatar
Where would that be located
Old 06-04-2014, 08:54 AM   #4
TigerPride
cajunrvr's Avatar
Would it be in the panel outside r maybe by the water filter and witerizing valve
Old 06-04-2014, 09:25 AM   #5
AKA: 'tiredTeacher
awellis3's Avatar
Yes. It is next to the heater itself. There are 3 valves. The ones on the cold in and hot out should be open (levers parallel to water flow). The 3rd valve, located on a line between the other two, should be closed(lever perpendicular to the water flow).
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 06-04-2014, 02:34 PM   #6
TigerPride
cajunrvr's Avatar
I found it and all is working well. Thanks to everyone.
heater, water, water heater
