Old 09-02-2014, 05:57 PM   #91
Snowsail
Snowsail's Avatar
Did anybody notice that the front caps changed design in 2012 or 2013. The new caps have less V grooves in them and I think this is what is causing the top of the new front caps to collapse, I have a 2013. 8280 diamond that was built in april 2012 and have no problem with the front cap but a friend of mine with a 2014 had his front cap collapse. F.R. should install the older model front caps to avoid this problem.
2013 Rockwood 8280WS signature, diamond package
2011 F-150, FX4,EB,6.5' bed
Snowsail is offline   Reply With Quote
Old 09-02-2014, 06:07 PM   #92
Plain Old Member
Nothing to do with the collapse, but you'd think they (Rockwood / Flagstaff) would have put pieces of styrofoam that fit in the framing. Lots of gaps there.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 09-03-2014, 09:32 PM   #93
dtomstant's Avatar
Stuffing complete. We'll see how it holds up. No problems noted from the dealer via bypass/interstate back to the storage locker.
Dealer also reset torsion axles and re-torqued the 8 bolts. We'll see on this one, as well.Click image for larger version
Name:	ImageUploadedByForest River Forums1409797885.475249.jpg
ID:	62085Click image for larger version
Name:	ImageUploadedByForest River Forums1409797902.402540.jpg
dtomstant is offline   Reply With Quote
Old 09-04-2014, 03:04 AM   #94
Witch Doctor's Avatar
I agree big john, but snowsail might have a good point to being that the groves also might help. Once again a design change. What really surprises me is that it is almost only the dark color caps. I just wounder if heat is also a culprit here? But stuffing isn't the answer, they need to pull the caps and fill that whole void, like that one picture, now that was nice work. That's how they should fix them all.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-04-2014, 04:25 AM   #95
Mine is headed back to the factory where they are going to replace the cap with a new one and add more foam.
albuilder is offline   Reply With Quote
Old 09-04-2014, 01:05 PM   #96
PhoneDude 8289's Avatar
I contacted FR about the dents and sent pictures. Also mentioned that the dealer here wouldn't look at it any time soon. I did hear back from FR, they told me I could take it to Dallas to get it fixed or I could take care of it as a DIY. They would reimburse the money for the styrofoam and sealant. Today I bought the foam at Lowe's and now I'm trying to locate the tan Dicor lap sealant, white is easy to find but will not due. FR told me that if stuffing it with the styrofoam didn't work they would authorize a new cap. We will be leaving for a month long trip in a week so I don't want to get it tied up a some repair center for who knows how long. Here are a couple of pictures of what it looks like now, I'll post more pics showing the repaired product
Name:	2014-08-25 09.09.43.jpg
Name:	2014-08-25 09.10.06.jpg
Name:	2014-08-25 09.12.48.jpg
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 09-04-2014, 05:06 PM   #97
We are having ours hopefully fixed in two weeks. An important note, ours leaked
bobandsue is offline   Reply With Quote
Old 09-08-2014, 12:34 PM   #98
Got the front cap stuffed with the Styrofoam 2 pcs 1" thick that FR recommended. Couldn't find 1" styrofoam sheets, bought a sheet of 1/2" and doubled it up. The entire job took about 4 hrs that included gathering material, tools and the tan dicor caulk that I needed. Once on the roof it took 1 1/2 hr start to finish. We will see if it holds up.
Name:	2014-09-08 10.18.31.jpg
Name:	2014-09-08 11.17.07.jpg
Name:	2014-09-08 08.37.50.jpg
Joe & Beverly
2014 8289WS lifted
Old 09-09-2014, 01:06 AM   #99
Were did you find the tan caulking?
cachencouple is offline   Reply With Quote
Old 09-09-2014, 07:09 AM   #100
Camping World
Joe & Beverly
2014 8289WS lifted
