Old 12-02-2014, 11:05 PM   #1
8289WS Aluminum Wheels
Can the aluminum wheels handle a tire that uses more pressure? Say 80lbs. Looking to upgrade to 10 ply tire and get rid of the china bombs. Could these wheels support such an upgrade?
THX
Kennyscott is offline   Reply With Quote
Old 12-02-2014, 11:19 PM   #2
B and B's Avatar
D is the Maximum you can run on stock rims. Max pressure is 65 lbs, can not remember but I did find that spec on a OEM site. Lions head site is vague on what the rims are good for. Most here run 55 to 65 on D on the Flagstaff/Rockwood stock rims. Also use metal valve stems but I still Rubber myself with no air loss or other problems.
B and B
Old 12-02-2014, 11:38 PM   #3
WFD
And the load range D should be more than adequate for that trailer....will be a huge improvement over the crap tires that come with the trailer.
B and B...are you happy with the Marathons?
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 12-03-2014, 02:14 AM   #4
Witch Doctor's Avatar
If you have the series 6 HTW they are rated at 60 lbs PSI, I run GY "D" at 65 lbs.
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-03-2014, 09:23 AM   #5
5er_tom's Avatar
I run LR E tires @ 70 psi. No issues so far and LOTS of excess carrying capacity, which I am happy about.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
5er_tom is offline   Reply With Quote
Old 12-03-2014, 10:14 AM   #6
WFD I run Marathons, had them balanced and steel stems put in, have about 4000 miles on them and they still look like new. Had Marathons on my old unit never had a problem knock on wood. In fact I have had them on every trailer I have ever owned.
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-03-2014, 10:34 AM   #7
PhoneDude 8289's Avatar
I'm running Maxxis 8008 LR E @ 75# with 800 miles on them now with no problems. Also had them balanced with steel valve stems and a TPMS on them at install.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 12-03-2014, 02:02 PM   #8
I contacted Lions Head directly prior to upgrading my tires on my 8280. They were definitive that the aluminum wheels were good for 65 max PSI and only a "D" load rated tire. True, you could put on a "E" rated tire but you would still be limited by the 65 PSI limit and its corresponding load. I ended up going with the Maxxis 8008 in the "D" range.
2014 Rockwood 8280WS
2010 Tundra 5.7 Dbl Cab 4x4
ronb707 is offline   Reply With Quote
Old 12-03-2014, 04:09 PM   #9
WFD
I guess I will have to shop around for price then this winter on some Marathons....and the steel stems just to a better job maintaining pressure?
Old 12-03-2014, 04:12 PM   #10
MarcusN's Avatar
I have LR E on my 8289 with about 3200 miles and run at about 75 lbs with no issues. Even though factory rates them at 65 lbs I am sure they are tested to 75 lbs during mfg as most every mfg product is tested about specified published ratings.
Mark & Barb
2013 8289WS Platinum Pkg
2008 F350 King Ranch CC 6.4
2013 nights camped 35
MarcusN is offline   Reply With Quote
wheel
