Old 08-22-2015, 12:24 PM   #1
8289WS Converter
Anyone know where it is?
txmissy is offline   Reply With Quote
Old 08-22-2015, 12:29 PM   #2
TURBS's Avatar
Behind or in your distribution panel.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-22-2015, 12:37 PM   #3
Do you mean the fuse box by the door? Thank you!!!
Old 08-22-2015, 12:39 PM   #4
TURBS's Avatar
Yes
TURBS
2011 32bhok Sabre
Old 08-22-2015, 12:41 PM   #5
Thanks, Turbs!
Old 08-22-2015, 12:42 PM   #6
TURBS's Avatar
Is it a wfco unit?
Fuse panel.
TURBS
2011 32bhok Sabre
Old 08-22-2015, 12:50 PM   #7
Yes. Having electric issue. Power at cg box is good. But without a charger on the battery nothing works. And with it charging microwave still doesn't work. Everything else does - acs TV etc. We thought maybe there was a fuse issue with converter. Too hard to get to, though.
Old 08-22-2015, 01:04 PM   #8
TURBS's Avatar
No 12v power?
TURBS
2011 32bhok Sabre
Old 08-22-2015, 01:12 PM   #9
Witch Doctor's Avatar
Take the screws out at the top of the lid then just pull the cover up and out. The convertor will just slide out nothing holding that part in. Have the same unit and went to progressive 50 or 55amp , should have got the 65 amp...Very easy to do.....
Coachmen M/H
Concord
2018 / 300 DSC
Old 08-22-2015, 01:12 PM   #10
DaveSchwartz's Avatar
All the user-accessible parts of the power center are behind the flip-down door of that brown box... the main AC breaker, AC branch circuit breakers and the 12VDC fuses (the multicolored plastic rectangles). The converter - the part that charges the battery - is integrated into (behind and underneath) the breaker/fuse area and has its own breaker to enable the AC to DC (battery charging function).
The microwave has nothing to do with the 12V side of the system (converter or battery), it runs strictly on AC. Its possible the breaker for it was tripped at some time. With most tripped breakers you need to move the handle fully to the OFF position before they can be reset to the ON position.
It happens fairly frequently that the battery gets hooked up backwards if it has been removed because, unlike a car, on a trailer the black cable goes to the +ve and the white goes to -ve (this follows the residential 'white is neutral' scheme). When this happens, the two 40A fuses (the brown ones on their own) will blow to protect that side of the system but everything AC should still work. They are awfully difficult to find in stores.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
converter
