Old 11-05-2013, 08:54 AM   #11
Send a PM to Old Coot and he will help you further.
Flying dutchman is offline   Reply With Quote
Old 11-05-2013, 08:57 AM   #12
TURBS's Avatar
Originally Posted by Lynkage View Post
Now that is a nice step support!!
Quite possibly the only one I have seen that would work worth a you know what!!
Where does one find these elusive supports?
Old coot.
Old 11-19-2013, 04:00 PM   #13
BamaBob's Avatar
Originally Posted by hammerhead View Post
What do you guys do to stop the shaking and rocking when someone is walking around inside.
Thanks for any info
We use the BAL 28012 X-Chock Tire Locking Chock for the wheels and the BAL 25066 Fastjack King Pin Stabilizer. With these and the rear stabilizer jacks down we have virtually NO shake, rattle or roll in our Unit.
Take a look on Amazon and, if you are a Prime member, the 2 items will set you back @ $175.00 and shipped free (remember you need a 2 pack of the X-Chocks)
Setup is a breeze -- I can have both chocks and the King Pin Stabilizer set up in under 8 min.
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 11-19-2013, 10:51 PM   #14
WFD
I will 2nd what HSVBamaBob just posted...we have the same chocks but a different King Pin Stabilizer, same idea. There is a night and day difference when you use them...sometimes when we are just stopping for the night where I don't bother with the King Pin stabilizer and you can sure see the difference...the wheel chocks work great and I wouldn't be without them.
Rick
WFD is offline   Reply With Quote
Old 11-20-2013, 04:57 AM   #15
Toy-aholic
What I found made a huge difference was not extending the landing gear as much as possible...ie setting them down on 6x6 blocks or more.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 11-20-2013, 08:03 AM   #16
WFD
The idea of the blocks is a good one, only problem with blocks is the bulkiness and the weight. They take up a lot of storage space, and they are heavy.
Rick
Old 11-20-2013, 09:27 AM   #17
BamaBob's Avatar
Thumbs up
Rick
Rick,
There's a sneaky way around this! We got a 4-5' section of 4x4" from a local crating company (free, but you could go to Lowes/Home Depot and buy one for less than $10)
Take a look at your front jacks and cut the 4x4 to be a few inches longer than the width of the jack cap. Presto! You have a 4" (well actually 3.5") extension block. (This will also work on the back stabelizer jack pads as well. Total added weight for all for blocks is maybe 5 pounds?
One small problem department: This method is great on concrete, not so good on gravel, and absolutely sucks on soft ground!
Solution: Buy these: Amazon.com: Camco 44541 RV Large Stabilizer Jack Pad - 2 pack: Automotive=
or their smaller versions: Amazon.com: Camco 44595 RV Stabilizer Jack Pad - 4 pack: Automotive=
We use these and the blocks all the time - even on concrete, effectivelly raising the jacks almost 5"
Old 11-20-2013, 09:45 AM   #18
Took some Camco blocks and covered the top & bottom with alum tread plate and bolted them to the jack pads. Works great on gravel, soft ground or concrete. Have now painted them all black.
ID:	42858   Click image for larger version
ID:	42859   Click image for larger version
Old 11-20-2013, 11:23 PM   #19
WFD
Old Coot...what are the white boxed things we can see under your rear bumper? Are those PVC boxes to hold your sewer hose?
Rick
Old 11-21-2013, 08:15 AM   #20
Fulltime family RVer
Rick
People use them for a lot of things- sewer hose, collapsible ladders, rugs, etc.
Here's a thread on how folks are making them:
Storage box for sewer hose?
fifth wheel, wheel
