Old 11-05-2013, 08:37 AM   #1
8289WS Fifth Wheel shaking
What do you guys do to stop the shaking and rocking when someone is walking around inside.
Thanks for any info
hammerhead is offline   Reply With Quote
Old 11-05-2013, 08:40 AM   #2
TURBS's Avatar
Thanks for any info
Jack stabilizers.
Use the search function you'll likely find hours worth of reading for your enjoyment!
Search "stabilizer"
Heck I did it for you.
http://www.google.com/search?q=stabi...W_enUS514US514
Good luck!
Turbs
Old 11-05-2013, 09:18 AM   #3
tomjsas's Avatar
Some have installed JT Strongarms. Heard they help alot. Been thinking of doing it as well, but then I do have to tell myself I'm camping and I have to rough it a little bit
Tom
Pull-Rite 16K Super 5th
2014 Rockwood Signature Ultra-Lite 8289WS
2011 Chevy 2500HD - DuraMax (Just over 5000 miles now!)
Nights camped in 2014 - 21
tomjsas is offline   Reply With Quote
Old 11-05-2013, 09:18 AM   #4
The best result you will get if you do what OC (aka Old Coot) did with his 5er of similar size. Front, back and close to axles. Highly recommended.
Flying dutchman is offline   Reply With Quote
Old 11-05-2013, 09:20 AM   #5
AKA: 'tiredTeacher
awellis3's Avatar
OK, HH, here's the raw truth. As long as the trailer's weight is on the suspension, you will get movement. That's why those Class As have "levelers," not "stabilizers," to unload their suspensions.
Now, you can go to great effort and some expense to minimize the walking-around blues.
I use X-chocks to minimize forward-to-rear rocking. They help. One trip, I crawled under the trailer and put scissor jacks on the plates that carry the torsion tubes and that helped, too. But that procedure was a PITA for an old dude as I.
Some folks swear by the add-on stabilizer braces and I'm sure they help, too. BUT, the bottom line is - as long as your suspension is carrying the weight of the trailer, you will get movement. You must decide how much extra set up time and dollars you want to throw into a partial solution.
After setting the OEM stabs and putting the X-chocks in place, Penny has declared that good enough. Leveling and stabilizing is back to an under-10-min. operation and we're good with that.
Teach
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 11-05-2013, 09:21 AM   #6
Herk7769's Avatar
X-chocks seem to stop the front to back rocking; the stabs (like jack stabs) seem to stop the left to right.
Name:	Camper Photos 016.jpg
ID:	42311   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 11-05-2013, 09:24 AM   #7
Fulltime family RVer
My process has been:
1) Triangulation at the stabilizers (I used UltraFab Eliminators, but there are also JT's StrongArms, SteadyFast system and homegrown DIY solutions)
2) Between-the-wheel wheel chocks (I used RotoChoks, but there are also BAL X-Chocks)
We still have a good bit of movement.
I tried the Valtera Stabilizer Stand cross-ways near the axle and it didn't make a lick of difference. I'm going to get a couple of scissor jacks and put them there to see how it does.
As well, I want to get a step-support for each set of steps.
ependydad is online now   Reply With Quote
Old 11-05-2013, 09:39 AM   #8
TURBS's Avatar
Oc step support. ....
Old 11-05-2013, 09:49 AM   #9
Witch Doctor's Avatar
You are always going to have movement unless your put the trailer on a foundation. You can help stop it by the ways mentioned above but you will still have some. The first thing that I did that really helped was to get a stair step support. I got mine from the oldcoot. He will sell you one just send him a PM. That really helped the most. After I got rid of that motion from going in and out of the unit, I still had rocking walking around inside. I then put on the JT strong arms. They also helped enough that my wife is now happy and it made it pretty solid. I really never felt the forward and backwards movement so I have never used the roto chocks between the wheels. Just by doing those 2 things I feel my trailer is solid enough for me. But everyone is different, after all it is a trailer on wheels. Some people swear by the king pin stabilizer but I really do not think they really help, but that's my opinion.
Name:	JT ARMSTRONG 001.jpg
ID:	42317   Click image for larger version
Name:	JT ARMSTRONG 006.jpg
ID:	42318   Click image for larger version
Name:	Awning bracket and the locking hook 003.jpg
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-05-2013, 09:50 AM   #10
Lynkage's Avatar
Now that is a nice step support!!
Quite possibly the only one I have seen that would work worth a you know what!!
Where does one find these elusive supports?
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
fifth wheel, wheel
