Old 08-25-2014, 10:40 AM   #91
Witch Doctor's Avatar
Originally Posted by OldCoot View Post
And guess who ask for the drawings to put shocks on?
You need to see a Doctor about your EGO problem, maybe they can help you out. I wanted the drawing to show my repair people who built custom only from the frame up to delv. To see if it would make a difference which I still stand behind. For some reason you think your the last word on everything. This is not true. Their are some pretty smart people out there besides on this forum. I try to get as much knowledge as I can before I do anything. Sorry if it upsets you....Have a nice reunion in Mo.....
Coachmen M/H
Concord
2018 / 300 DSC
Old 08-25-2014, 10:46 AM   #92
After all the guff you gave me about them, why would you even consider them if you haven't changed your mind?
Old 08-25-2014, 11:00 AM   #93
TURBS's Avatar
TURBS
"SABRE OWNERS UNITED"
Old 08-25-2014, 12:34 PM   #94
Thought I just told you, having a CRS problem again?
Coachmen M/H
Concord
2018 / 300 DSC
Old 08-26-2014, 05:27 PM   #95
LouNick's Avatar
Check to see if the axles are held in place thru the side like FR products or thru the top of the support like they should be.
The boat trailer axel has a bracket that's welded on the sides and top. That bracket is then U- bolted to the frame. Funny how the axel isn't straight though. It has a saddle in it. I guess the torsion bar only extends about 18 inches into the axel tube. Tapping on the center, it sounds hollow.
I can see how the RV bracket was used for additional height. Mine is welded all the way around on the inboard side and on the top on the outboard side.
Name:	ImageUploadedByForest River Forums1409091890.594787.jpg
... And here is the boat trailer:Click image for larger version
Name:	ImageUploadedByForest River Forums1409092016.489567.jpg
Name:	ImageUploadedByForest River Forums1409092052.959833.jpg
Lou and Paula
2014 Rockwood 8289WS UltraLite w/Revolution Pinbox Engaged.
2011 F250 Power Stroke Super Duty King Ranch Super Crew Cab w/Reese 16K Hitch
Lou & Paula
2014 Rockwood 8289WS Ultra Lite w/Reese Revloution Pinbox.
2011 F250 Power Stroke Super Duty King Ranch Super Crew w/Reese 16k Fixed Hitch
LouNick is offline   Reply With Quote
Old 08-26-2014, 07:11 PM   #96
Originally Posted by LouNick View Post
The boat trailer axel has a bracket that's welded on the sides and top. That bracket is then U- bolted to the frame. Funny how the axel isn't straight though. It has a saddle in it. I guess the torsion bar only extends about 18 inches into the axel tube. Tapping on the center, it sounds hollow. I can see how the RV bracket was used for additional height. Mine is welded all the way around on the inboard side and on the top on the outboard side. Lou and Paula
From the picture, it looks like they are held with a side bolt in a slot also. Thought I saw a hole it the support in the top that wasn't used either, just like on the rv trailers.
Old 08-27-2014, 07:11 AM   #97
LouNick's Avatar
Are you referring to the picture with my fingers in it? That pic is my RV. What is the concern about how the RV is attaching the axle? The twisting action that the torsion axle experiences?
Lou and Paula
Lou & Paula
Old 08-30-2014, 09:55 AM   #98
Ok well looks like this post took a severe turn in a different direction.
2013 F150 Platinum EGOboost, 3.73 max tow
PrinceValium is offline   Reply With Quote
weight
