Old 08-24-2014, 03:44 PM   #81
Originally Posted by gljurczyk View Post
I guess If FR/Lippert thought I needed shocks they would have put them on. I understand what you do and like to do OC , but really they are not necessary...Why make a mt. out of a mole hill?
You are going to dolphin no matter what my truck has 4 shocks brand new the best that can be bought...
What I am trying to convey to you is the shocks on the trailer stop the dolphining while towing. BTW, you do not dolphin without a trailer it's just bouncing on crappy FoMoCo suspension.
I believe you are the one making a mountain out of a mole hill. I got mine fixed.
in your buckin' bronco.
Old 08-24-2014, 09:31 PM   #82
Owner/Operator
RodeoGeorge's Avatar
gljurczyk,
I see in your sig that you have the 4 point level up.
When I inquired about getting it installed on my 8289WS I was told that the frame was too weak to use that system.
Who installed for you, or was it a DIY?
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 08-24-2014, 09:39 PM   #83
B and B's Avatar
You are going to dolphin no matter what my truck has 4 shocks brand new the best that can be bought (recommended by turbo and my wife even said thanks to him) and my truck will still bounce towing or not. For 3 years I have left a coffee pot on my counter and also nothing falls out of my cupboards or refer when I stop and open them. To each his own the mods you helped me with where for convenience for me which I will always be grateful for but that has nothing to do with shocks to make the unit ride easier. We are not comparing apples to apples here. I added the 4 pt because I got tired of an uneven trailer and now it stops all arguments about the shower not draining or the doors won't stay open or I'm walking up hill, no more of that anymore. Only problem now is that I have to buy more crap to load in the front end to increase my pin weight. Now that's a great problem to have.....
I don't like like a shower that doesn't drain either, I leave the nose a tad high to stop that.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 08-24-2014, 09:51 PM   #84
Originally Posted by RodeoGeorge View Post
gljurczyk, I see in your sig that you have the 4 point level up. When I inquired about getting it installed on my 8289WS I was told that the frame was too weak to use that system.
Who installed for you, or was it a DIY? RodeoGeorge
Glenn got the system in Goshen at the rally. I think they told him that his was the only one they would do after installing his. They had to do a lot of reinforcing to his frame, etc. Took the better part of a day.
Old 08-24-2014, 10:09 PM   #85
B and B's Avatar
They will install a motor driven system I was told by lippert. I guess I am thinking the cost of such is over improving the 8289. Looking that we most likely will get another 5th wheel to retire into. Will buy all the gadgets on that one.
Old 08-25-2014, 03:41 AM   #86
Witch Doctor's Avatar
gljurczyk,
RodeoGeorge
George, I had it installed by Lippert at the Rally, took them all day from 7:00AM to 4:30PM at the plant. I was suppose to get a 4 point electric, but Monday I talked to the head Engineer of Creative design. He said do not go with the electric and it was to slow. So they talked me into the hydraulic level up, the show price was 4200.00 installed, the electric was 3200.00. When they seen it was a Rockwood they called in 2 welders. Had to reinforce the frame with 2-2x2 cross beams and then added 2 I think it was 3/16 channel about 3' long right behind the rear axle. they removed the front landing gear and installed the pump and tank in the corner, which really gives me more storage area. They hung the control panel in the locker so it right there when I open the hatch. They said that I will have no twisting that I was afraid of. Also said it was the first one they did. They tried to charge me 4600.00 due to the welding and I said no. Talked with the same Creative engineer the next day, he said they had to due alot of reinforcing, but being they only could do a 4 pt. he called them and had them drop the price to 3600.00 he said a deal is a deal those jacks cost about 500.00 each. So i got a good deal. Any problems it is on Lippert they installed it and straightened the frame. The welder told me that he doubted they would ever do another Rockwood, but the creative engineer was great about the whole thing, Glad I got it done, don't plan on buying anything else because we love the trailer and plan to keep it. In about 3 mos they are coming out with what is called a black cat system, each ram will have it own reservoir and then they just plug in the electric to run the pump on the ram no more hydraulic hoses but the frames will still need the welding to stop any flexing at all.... Lippert interviewed me and took pictures of the install.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-25-2014, 03:49 AM   #87
I guess it depends on what you paided for your 8289WS. I don't call it over improving. What are you saying that your unit is junk?
Old 08-25-2014, 06:12 AM   #88
PhoneDude 8289's Avatar
gljurczyk,
RodeoGeorge
Yes it is a DIY. There is at least one other with the 8289 that had theres installed at the rally. I'm pretty sure that the work that was done out there on any unit was done by FR techs. I have had mine on a couple of months and love them. I could see how if you get crazy with them you could twist the frame.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 08-25-2014, 06:35 AM   #89
Originally Posted by presley01 View Post
Yes it is a DIY... I have had mine on a couple of months and love them...
Question, if it is a DIY, who did yours?
Old 08-25-2014, 10:06 AM   #90
And guess who ask for the drawings to put shocks on?
weight
