Originally Posted by 5er_tom
RodeoGeorge,
You will need to unscrew the right side hinge.You should have gotten a tool for that with the 5th wheel. I did. It is the same tool you use to access the water filter.
Thanks Tom. We haven't taken delivery yet, they are doing the prep, and it will probably be Friday when we pick it up.
I would think that they used the #2 Robertson Screws (the square head) for the hinge, and I would not leave home in an RV without that style of bit.
From what you said, I surmise that the Water Filter is also behind some compartment panel. Possibly one in the understorage since that is in the vicinity of the City water inlet.
Those panels will be coming of shortly after delivery, as I'm hoping to be able to install a central vacuum system to the rear of the storage panels.
I've got a shop full of "stuff" to install. 2025RV Battery Monitor, PD9260 Converter, Progressive Industries 50A Wired Surge Protector, two Wireless Awning Remotes, TPMS, two Trojan 30XHS Batteries, etc. I've got to stop reading the posts that Herk and Turb submit. LOL
Then I'll be looking for a way to run wires from the roof to the battery compartment for a solar panel. That will be a challenge, as I normally come down through the Fridge Roof Vent, but with the Fridge being in the slide that's not possible. I have come down a holding tank vent and out the side in the under storage on some RVs. Just seal the point where the wires come out good with silicone, AND make sure that the point you enter the vent is above any place where water is flowing.
The wife has a question reagrding where to put cleaning supplies in the kitchen, but I'll post that in a new Thread.
We got very little snow from the last storm, and now are forecast to get up into the high 70s by Thursday with lows finally above freezing. Of course, it will then cool back off for a while before we get into the summer weather.
Thanks again for the info.
RodeoGeorge
