Old 08-21-2014, 02:47 PM   #1
8314SS Awning light won't go out!
Just got myself a 2007 8314SS and after charging the battery find that the orange light, just above the kitchen window, will not go out. I've searched high & low and cannot find a switch. Please help a newbie out.
Thanks!
EnglishAndy is offline   Reply With Quote
Old 08-21-2014, 02:54 PM   #2
Possibly on a wall near a door, usually 40-46" high? only other wall switch for me is to extend/retract the slide, which is mid-deck and labelled as same. Good luck!
Jim, Alison & Murphy the goldendoodle
2004 Grand Surveyor by Forest River
26 ft. with Sofa Slide purchased in 2013
Upgrade from 2004 8 ft. Flagstaff by Forest River
Jim2 is offline   Reply With Quote
Old 08-21-2014, 05:08 PM   #3
Do you have a remote? On my camper, if you turn the porch light on with the remote, it won't turn off with the switch inside the camper.
Glen & Lee
Dawsonville, GA
2013 V-Cross Platinum 325VRL
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
Old 08-21-2014, 05:49 PM   #4
There's very few switches in the trailer and I've tried them all. I never got a remote with it and I think it's possibly too old to have one. It's a shame because I can't find the battery disconnect either and so it's killing my battery.
Old 08-21-2014, 11:19 PM   #5
Every light has a switch. Be it on a wall or on the light itself.
Keep looking.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 08-25-2014, 08:39 AM   #6
I am sure (hoping) that there is a switch for it. I just can't find it. I'm hoping someone on these forums has the same year and model, a 2007 Rockwood 8314SS. Maybe they can take a look and see what controls that light. I'm getting ready to start ripping trim and cabinets out to trace wires!!!
HELP!!!
Old 08-25-2014, 09:25 AM   #7
fonzie's Avatar
Above the sink and under the kitchen upper cabinets are some switches. Have you tried them to see if light turns off? Do you have one switch that seems to not turn anything? Switch might be bad and shorted?
Fonzie
Old 08-25-2014, 09:25 AM   #8
mikev's Avatar
Andy, welcome to the Forum.
I once had a 2007 Rockwood Signature Ultra Lite that was not the same model as yours, but may have had a similar wiring scheme.
As I recall, there were some almost hidden and nearly flush mounted small rocker switches located on the underside of a kitchen wall cabinet that was hung directly above the kitchen sink and/or stove top. You might try looking there in your unit, just in case you haven't already spotted and tried those switches.
Good luck!
Mike
2013 Rockwood 8329SS Diamond Package
2008 Ford F250 Lariat SD Crew Cab 4X4
mikev is offline   Reply With Quote
Old 08-25-2014, 09:41 AM   #9
TURBS's Avatar
Originally Posted by mikev View Post
andy, welcome to the forum.
I once had a 2007 rockwood signature ultra lite that was not the same model as yours, but may have had a similar wiring scheme.
As i recall, there were some almost hidden and nearly flush mounted small rocker switches located on the underside of a kitchen wall cabinet that was hung directly above the kitchen sink and/or stove top. You might try looking there in your unit, just in case you haven't already spotted and tried those switches.
Good luck!
Mike
x2
I had an 05 and there are switches under the upper cabinets.
turbs
"sabre owners united"
Old 09-06-2014, 03:50 AM   #10
fonzie's Avatar
Have you found the switches???
Fonzie
awning, light
