Old 05-25-2014, 06:18 AM   #1
A/C not cold
We are out camping and I noticed that our a/c isn't blowing cold air like it normally does. Last season we would leave it on at night, but have to close the blind in front of the bed so it didn't get too cold. And that was on the low setting. Last night I left it on low and woke up around 2am because of how warm the camper was so I put it up to high. Woke up around 6 and the camper felt a little cooler, but when I opened the door it was actually cooler outside than in the camper. Normally on high I would have to wear a coat to bed if I didn't want to freeze. I can hear the compressor kicking on, the air just doesn't seem very cold, only cool. For reference it was only 70 last night, so should have make the camper an ice chest. It's a 2109s.
2013 Mini Lite 2109s
2006 F150 STX 4x4
Smitty75 is offline   Reply With Quote
Old 05-25-2014, 06:25 AM   #2
Ford Idaho's Avatar
Restricted air filter?
Low on Freon?
Old 05-25-2014, 06:38 AM   #3
Cleaned the filters, they weren't too bad. Seems like it's cold when the compressor first kicks on when you fist start it, but after a couple minutes the compressor cuts out and it goes back to just cool. Wondering if it's the thermostat or something not kicking the compressor back on, or on often enough.
2006 F150 STX 4x4
Old 05-25-2014, 07:04 AM   #4
PhoneDude 8289's Avatar
Switch unit off. Take the cover off the unit on the roof. Check and clean if necessary the condenser coils. If they are very dirty or cloged will shut down the compressor on high head pressure or (thermal overload compressor too hot).
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 05-25-2014, 12:33 PM   #5
AKA: 'tiredTeacher
awellis3's Avatar
Stop wondering and measure. Put a thermometer in the A/C duct to measure output temp. Put another thermometer near the thermostat to measure ambient air temp. Set the thermostat just low enough to make the A/C turn on. Note the time, ambient temp and output temp. Keep taking these readings at set intervals (every 2-5 min.) until the unit cycles off. Keep measuring until the unit cycles back on. This will give you a clear picture of what the A/C is doing, how much and when.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 05-25-2014, 03:19 PM   #6
dan-nickie's Avatar
What temp is your thermostat set at?
2014 Berkshire 390RB-60
Dan
dan-nickie is offline   Reply With Quote
Old 05-25-2014, 04:06 PM   #7
Unfortunately it is an all in 1 unit, low cool and high cool. The thermostat is built into it, just has a turn knob with red on one side and blue on the other.
When I get home from camping I'll dig Into it. I will start with pulling the cover off and cleaning everything good. I don't think it's a voltage issue, but I will verify with a meter.
2006 F150 STX 4x4
Old 05-25-2014, 04:58 PM   #8
dcheatwood's Avatar
Could red/blue temp control be stuck in partially red/warm area?
Sent from my XT907 using Forest River Forums mobile app
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 05-25-2014, 05:28 PM   #9
FYI You should have about a 10 degree drop in temperature from return to discharge.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
