Old 07-02-2015, 11:50 PM   #1
Alberta8311ss's Avatar
A/C runs non stop
Just checking if any other rockwood owners have a/c units that run non stop when it's warm out. Seems they under sized ours. At 28c / 82f it has run on high and not cycled once. Assuming I have a 13,500 unit not the 15k
2014 Rockwood 8311SS
Alberta8311ss is offline   Reply With Quote
Old 07-02-2015, 11:57 PM   #2
crunchman12001's Avatar
Make sure your thermostat fan setting is on "Au"and not hi or low.
Au stands for auto. Hi or Low will cause the fan to not turn off
crunchman
2015 F-250 FX4
Old 07-03-2015, 02:49 AM   #3
Move here - not that many hot days
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017
CNYCamper is offline   Reply With Quote
Old 07-03-2015, 09:27 PM   #4
Fivealive's Avatar
I had a bad relay in our mach 5 causing the same type of problem. I had to trip the breaker to turn it off. Warranty fix and I replaced the analog thermostat with a digital one because I felt I welded the relay by over cycling the a/c when adjusting the temp. Digital has a time delay.
Fivealive is offline   Reply With Quote
Old 07-03-2015, 09:30 PM   #5
Cyber Phrenologist
Radio's Avatar
See if plugging up a few holes might help...
Newbie with air conditioner that can't keep up?
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 07-03-2015, 09:53 PM   #6
WFD
Pretty normal...especially if you are parked somewhere with not much shade. These trailers are not like our homes, not much insulation in them. As others have said, open any cupboard on the side of the trailer in the sun and the heat there will show you just how hard the a/c has to work.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 07-04-2015, 11:52 AM   #7
dcheatwood's Avatar
Mine ran so long a few nights ago that it was 57° in the camper when I went out and saw the windows dripping condensation. Had to throw the breaker to kill it. plan to replace with digital soon.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 07-04-2015, 12:36 PM   #8
To summarize, you may have one of 4 problems (in order of probability):
1. Fan is in ON (run's constantly) and you don't realize that the compressor is cycling on & off - put fan in AUTO; it will then cycle with the compressor.
2. Lousy analog thermostat - replace with digital
3. Too hot outside, AC can't keep up - deal with it.
4. Bad relay - replace relay
2011 Traverse LT, 3.6L, FWD
Old 07-04-2015, 01:51 PM   #9
May have lost freon. Mine was only 6 months old when it done it. Take a meat thermometer check outside air going into a/c then check air coming out should be at least 15 degrees different.
Myrle is offline   Reply With Quote
Old 07-04-2015, 08:16 PM   #10
Oops. Forgot problem #5!
