04-25-2017, 08:36 PM
#21
Originally Posted by Mr. Dan
Window to Edit is open 2 hours.
Oh well, suppression is alive and well . . . . . .. .. .
04-25-2017, 08:40 PM
#22
What do you mean by that?
You can add info. like you did or you can PM a site team member to turn on Edit.
04-25-2017, 08:52 PM
#23
The edit mode apparently has a expiry of between 4 and 6 hours. That is set by the site sponsor. It differs between forums, that is all I was pointing out.
It is what it is . . . . . ..
04-25-2017, 09:07 PM
#24
I'm sorry but that makes no sense. A site team member (me) just told you our Edit window closing interval is two hours and you come back with that "4 and 6 hours" comment. No, it's two (2) hours. The Rockwood sub-forum is part of the overall Forest River Forums site. So is the Wildcat sub-forum. So is the Dealer Review sub-forum and the Propane Systems sub-forum and the Sunseeker sub-forum. Each and every sub-forum on the forestriverforums.com has the same 2 hour Edit window. It was like that before you joined. It was like that before I joined. It is not suppression.
04-25-2017, 10:04 PM
#25
Two hours, OK it is what it is ........
I belong to a generator site, two Goldwing sites, a dirt bike site, a couple of machinists sites and you can edit your posts in eternity.
You have a very special site here, take that comment anyway you want.
Having said that provocative statement, your site has a lot of information that is useful to the members.
04-25-2017, 10:09 PM
#26
Traverse forum only allows a couple hours.
2011 Traverse LT, 3.6L, FWD
04-25-2017, 10:33 PM
#27
Again, it is what it is.
These parameters are set by the forum host.
I am OK with the limitations.
The problem is people get used to them . . . . censorship.
04-25-2017, 11:45 PM
#28
"Just because you're paranoid - doesn't mean they AREN'T out to get you!"
Seriously, after a day or so, or after 5 or 10 posts, most people don't bother to go back and read them, so even if you had modified it, no one would read it.
04-26-2017, 12:08 AM
#29
Different sites different rules. If this site did allow unlimited editing feedback might not make sense as time goes as posts get edited. It isn't needed often but we can turn the editing window back if necessary. Most members will just post updates or corrections in the thread which helps feedback directed correctly.
Glad to hear that you find this site helpful as I have.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
04-26-2017, 07:55 AM
#30
I notice the site has a time out also. If you are not reading posts or posting yourself you get signed out. I have one other forum that has the time out feature enabled.
04-26-2017, 10:47 AM
#31
A question about Rockwood Model 2104.
Correction on weight Tacoma is rated to pull
Originally Posted by JHurtgen
The dry weight of our 2304 Mini Lite (model year 2011) is 3947 lbs. The GVWR is 4951 lbs.
Our 2014 Toyota Tacoma is a double cab, TRD off road 4x4, rated to pull 6500 lbs.
Your weight distribution hitch and sway bars add considerable weight, also.
We never travel with fresh water and only 2 gallons in the black water tank with GEO method solution in it to slosh while driving.
Here is a picture of our label, hopefully
04-26-2017, 11:28 AM
#32
Our 2014 Toyota Tacoma is a 6 cylinder 4x4, rated to pull 7500 lbs.
Remember that your weight distribution hitch and sway bars add considerable weight, also.
Here is a picture of our label, hopefully Attachment 135959
Thanks for your information. I should be OK with the added weight of the equalizer hitch and Friction Sway Control Bar.
I have a 2005 Chev Silverado, 5.3L V-8, tow/haul package, 4.10 rear end.
Maximum trailer weight 8,300 lbs, GCWR 14,000 lbs.
My truck Weight Information
Curb Weight 5,164 lbs
Gross Vehicle Weight Rating 7,000 lbs
Max Payload 1,836 lbs
On paper my truck should not have a problem with a trailer such as the 2304. I started looking at the single axle 1905 and then found a 2104 dual axle without slide. The 2104 is approximately 400 lbs lighter than the 2304.
There is only two of us so either the 1905 or 2104 is large enough.
Again, thanks for the help.
