Only downside to plugging into an outlet on your trailer is that the charger will use a portion of the power available to your trailer. You can only use 3600 watts in total. If you run the microwave, are charging house batteries off the converter, and maybe running an electric heater or two, you've maxed out the capacity of the 30 amp outlet on the campground shore power source.
This is of course an extreme scenario but something to be aware of. Some people using a 30 amp campground power source often have to run a second power cord to the post, plugged into the 15 amp outlet, just to run an extra heater, insta-pot, etc.
