Old 06-04-2011, 05:45 PM   #21
2Susan's Avatar
Daisy,
I am interested in the upgrades to make the a/c more efficient. I would love to see some before / after pictures.
2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
2Susan is offline   Reply With Quote
Old 06-05-2011, 06:36 AM   #22
Sid,
Did you modify the A/C cover on the ceiling or are you saying you opened the vents in the cover? And, does your A/C now cycle on and off in the 95 degree days?
PatrickCrotty is offline   Reply With Quote
Old 06-05-2011, 07:28 AM   #23
DAISY BOYKIN's Avatar
Patrick, no cover mod--------
Patrick, No I did not modify the cover, only inside the plenum box. There is a last picture that I should have made of the final completed mod. But it was so hot inside my"ROCKY" that I was in such a hurry to reassemble the A/C and get it working. If I remove the cover this next week for a follow up of the mod, I will make sure I make some more pictures. I more than doubled the opening to the vent ducts. If you look closely at the pictures I posted, you will see the before taper of the Styrofoam and after the taper. I even increased the taper more than the photos show.
The A/C will now cycle as designed after the "COOL DOWN". I am also using the window covers (Covers I made that is placed inside). I have tested the mod setting in my driveway. The 8285WS sets with the door facing east, bump out for living room facing wast. I also had the awning extended. The tempature outside was 91°
Getting rid of the heat from the bath from the film I applied reduced the work the A/C had to overcome to reduce the working load of the BTU's of the A/C.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is online now   Reply With Quote
Old 06-05-2011, 09:49 AM   #24
Sid,
So if I'm understanding you, you removed the cover and made your modification on the inside of the unit where the ac enters the ducting. You said you posted pictures, but could not find them.
Patrick
Old 06-05-2011, 10:18 AM   #25
Patrick LOOK AT POST---------
Patrick look at post under "FORUMS MODS". It starts by a post of "INCREASE A/C VENT AIR FLOW BY 75%"
Old 06-05-2011, 10:47 AM   #26
Already 91° here in florida-------
Already 91° here in Florida outside, inside the 8285WS the digital readout was at 89°, turned on the A/C with a setting at 76° on the thermostat. Took one and one half hour to bring the temp down to 76° and a shut down of the A/C to the set temp. No awning out, just the ones that are over the bump-outs. My RV is setting North and south.
Old 06-05-2011, 07:05 PM   #27
I don't even have a fiver yet, but am planning on doing this mod when I first get it!!!
Will this mod void the warranty?
reubenray is offline   Reply With Quote
Old 06-05-2011, 07:57 PM   #28
Herk7769's Avatar
Totally.
HAM CALLSIGN - KC3FFW
Old 06-23-2011, 05:52 PM   #29
Have a rockwood 8286ws 2011 ran the air in the am for about 4to5hrs went to the beach for about 4hrs, returned to camp, and was told by fellow campers thay heard a loud noise, and saw a puff of white smokehave this come from the top of our 5er, scared the ---- out of us, took to shop found the inline crimped connection blew apart, any one else have this problem
EAGLEMAN is offline   Reply With Quote
Old 06-23-2011, 09:27 PM   #30
RubenZ's Avatar
95 degrees is awesome. We just got back from camping at garner state park Texas and had 4 days of 100+ temps. Even at sunset it was close to 90 degrees.
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
