Old 08-06-2016, 11:37 AM   #31
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Coletrain182,,,post a pic of those caps from the top at an angle. I can't tell if they're bulged up or not,,,,,but regardless,,,,I've not recalled having one that could still read the MFD and be buldged up,,,,so they are probably ok.
Grampa Jim is offline   Reply With Quote
Old 08-06-2016, 11:46 AM   #32
Witch Doctor's Avatar
The fan cap looks bulged to me to, but he is putting the new one in also. 7.5 MFD's are cheap anyway. Coletrain if you read this get a SP6 hard start for the compressor while your up there. They are cheap and do work and will help save your compressor...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-06-2016, 12:28 PM   #33
Fivealive's Avatar
I installed the OEM digital Coleman Digital RV Thermostats | RV Digital Thermostats. Quick job, even used the same screws. No more fear of toasting the contacts using the non-digital model.
Fivealive is offline   Reply With Quote
Old 08-06-2016, 01:18 PM   #34
Coletrain182's Avatar
Originally Posted by Witch Doctor View Post
Any honeywell battery will work, Some people put in a set back but I think it's a waist of money unless you have park model or a full timer living in it for work. Remember you will only have one fan speed unless you add a switch. Cost between 21.00 to 31.00. also some put in a hunter I like honeywell better IMO. DO NOT HOOK THE GROUND UP....
I appreciate it! I went with a Honeywell!!
Coletrain182 is offline   Reply With Quote
Old 08-06-2016, 01:21 PM   #35
Head Rambler
As said above, any thermostat that is powered by batteries and will operate a millivolt system.
Take pictures of the wiring connections before you unhook them. It makes it easier to convert the wire colors to functions.
If you unit is a Coleman the wire colors follow.
Red = +12v (Hook to ""R"/RC" terminal)
Yellow = Comp (Hook to "Y" terminal)
White = Furnace (Hook to "W" terminal)
Blue = -12v (Not Used)
Gray = Low Fan (Not Used)
Green = Hi Fan (Hook to "G" terminal)
You can hook the Gray to the "G" terminal if you want low fan speed instead of high (Not Recommended).
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-06-2016, 09:14 PM   #36
Coletrain:
This may help you. If you don't want to be able to change fan speeds, pick one and forget the switch.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
