Old 12-31-2018, 02:42 PM   #11
bedubya's Avatar
Originally Posted by Toddupton View Post
Just take off the mattress and you should be able to reach down and get it.
There is still no access. The mattress platform swings along the curved wall. (At least on mine.)
'17 Toyota Tacoma 4x4
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
bedubya is offline   Reply With Quote
Old 12-31-2018, 02:54 PM   #12
Old Engineer
FleckDreher's Avatar
Slipper Retrieval
Go to Harbor Freight and buy a "spring type flexible retriever" with the four hook fingers that extend when you push the button at the other end.
$3-4 is cheap and you will need it again.
2019 Dynamax Isata 3 24RW
Smart Car Towed 4 Down
FleckDreher is offline   Reply With Quote
Old 12-31-2018, 03:00 PM   #13
My old reliable method for retrieving objects that are hiding in spaces too small for my arm is a good old fashioned wire coat hanger. Unfasten it at the hook end,and straighten. Put back any bends you need to make it a good fishing/sweeping tool. Once you've moved the object to where you can see it, perhaps you can hook it with the coat hangar and lift it out.
If you look in the pass through storage areas you'll notice that the panels separating the area behind the Murphy Bed and storage area are secured by screws through a piece of 3/4"x3/4" wood strip. Remove these screws and you can open a window into the storage area by just moving one end. Shoulsn't need to resort to any sawing.
I have it on my dog's authority that an afternoon nap is acceptable.
Politically Incorrect since 1943
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 12-31-2018, 06:34 PM   #14
Been there twice
We call that space the Hole of Doom.
Take 2 yard sticks and fasten them together at a right angle. Slip it down the headboard hole and move it around until the lost item appears. Then reach down and get it or use one of Harbor Freight grabber tools if you arm doesn't reach down there.
We keep that hole plugged with a body pillow when the bed is down - Bed Bath and Beyond ~ $20. It cuts off the cold air from pouring in past the mattress on cold days.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2000i Generator, 200 Watts Solar
Ham Callsign KD7UM
UT_Grandpa is offline   Reply With Quote
Old 01-01-2019, 03:38 PM   #15
Maybe they've changed recently, but I'm pretty sure the screws on mine are on the "hole of doom" side. You have to get into the hole to unscrew the screws. See the first pic in fella 10's Post #33 of the link below. You can see the screw heads on the inside of the far panel.
Space behind the Murphy Bed
2011 Traverse LT, 3.6L, FWD
Old 01-01-2019, 05:12 PM   #16
I have sent instructions and photos to 43 FROG members for a flip up shelf to fill the void behind the couch and a flip up headboard to fill the gap at the head of the bed. One of the requesters had said that their infant girl had slipped into that void!
I added removable access panels into that front void. But I did that because of another post that warned of the fact that inside that hidden area the the goodpeople of FR only installed screws in every other hole in the main piano hinge. And that, like his unit, the hinge on our unit was pulling away from the knee wall on both ends. I installed through bolts, which pulled the hinge back into position. Then I installed self tapping screws into the empty holes. That, not your daughters slipper, would be the main reason for you to create access holes.
Denny B is offline   Reply With Quote
Old 01-12-2019, 11:03 AM   #17
WoodLark-SC's Avatar
We use three "wedge" pillows to fill the gap at the head of the bed. It does not interfere with folding the bed up.
2013 Ram 1500 CC 4WD
2019 Rockwood 2503s
WoodLark-SC is offline   Reply With Quote
Old 01-12-2019, 07:24 PM   #18
Access to the underside of the Murphy bed
Our 2016, 2304KS has storage access doors on both sides of the trayler. Panels deny access to the underside of the Murphy bed. Do yourself a BIG favor and cut oopen these panels. You will find that F R only put screws in every other hole of the bed's piano hinge. The hinge WILL pull away from the knee wall/pivot point. Using through bolts, I was able to pull it back into position. Filled the emotyhols with self tapping screws, and added removable panels for cleaning and emergency access.
Old 01-12-2019, 07:29 PM   #19
I've also sent directions to 45 FROG members for a flip up shelf for the gaping, dog swallowing, casm behind the couch and a flip up headboard for the baby swallowing gap at the head. True story, one requester said their infant slipped into that void!
Again, do yourself a favor, repair and re screwthat main hinge, as it WILL eventually pull away!
Old 01-12-2019, 10:30 PM   #20
Thanks for the suggestions. Denny, I would be interested the in the instructions you have sent.
Snowbum007 is offline   Reply With Quote
bed
