Old 07-09-2014, 08:41 AM   #71
Windywest's Avatar
I have a Ford 6.5 box, revolution not activated, and lots of clearance all around. I carry lots of stuff in the box when we camp, nothing gets scraped and loose stuff is bungy corded to be secure, for us the setup as we use it is perfect for us.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
Windywest is offline   Reply With Quote
Old 07-09-2014, 10:14 AM   #72
BamaBob's Avatar
Originally Posted by gljurczyk View Post
Yea, if I were you I would, even in there direction it shows the only place to lubricate. But you know as well as I do that anything FR will say or there dealers you take with a grain of salt. I'm sure OC will say the samething. These two guys where the people who designed it not any rep. my question to you is how do you lube that pin without walking down the whole hitch? That is not a one person job. I will have them look at again in Goshen as you. Also mine took a lot more miles then that to get tight, really didn't happen until after I made my cross country trip.
I have a spray can of White Lithium grease I shoot between the plates. Since the hitch moves so easily (360 deg if I could) I just turn it, squirt some grease, turn again and more grease then moved back and forth a few times. I do this every time we go out.
But yes, we need to get a merry band together and corner Reese at Goshen and have them look at my rig and yours and OCs and compare them!
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 07-09-2014, 10:15 AM   #73
BamaBob's Avatar
Supercrew? See what happens if you start to Jackknife your rig - WARNING: have a spotter because you WILL dent your cab
Old 07-09-2014, 10:21 AM   #74
Originally Posted by HSVBamaBob View Post
...But yes, we need to get a merry band together and corner Reese at Goshen and have them look at my rig and yours and OCs and compare them!
Won't see mine, unless you come to Concord, NC.
Old 07-09-2014, 10:25 AM   #75
BamaBob's Avatar
Originally Posted by dtomstant View Post
Wouldn't I bump the cab (cap) with a 6.5 foot bed (F250), or close to it when making really sharp turns? Activated, mine has quite a bit of room forward of the cap.. Probably enough to fit my monster 10k generator without fear of scraping the bottom of the cap. But I wouldn't need to do that too often , anyway..
Originally Posted by WFD View Post
I would bet with a 6 1/2 ft box and your Reese activated...you would not have any issues...I can back mine and pretty much jacknife the trailer and not touch the cab...even with the Reese de activated, I can get awfully close to 90 degrees and not be touching the cab...but also depends on the design of your trailer cap.
Maybe...probably depends, like WFD says, on your end cap....
When our Reese was not activated, 6 Actual was practicing backing and she was jackknifing the 5er and truck. I was on the opposite side and just happened to wander around and stop her - as the 5er was about 6cm from the cab
So yes, if you jackknife, at least on a F150 King Ranch SuperCrew, towing a Rockwood 8289WKS/Diamond, you CAN and WILL dent the cab.
Old 07-09-2014, 10:26 AM   #76
BamaBob's Avatar
Darn it...I HATE that ya'll are not coming
Well I have the photos you sent me....
Old 07-09-2014, 11:59 AM   #77
Witch Doctor's Avatar
I agree you can hit the corner if you go over a certain degree. I tried before activation. How many miles do you have on your trailer since you activated it? I bet you a beer that you and I pushing on mine that it will not move, I used to like when i was able to turn it and get out of the way 90 degrees. I use to spray the pad and move it around all the time. It works great but sure has tightened up......
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 07-11-2014, 08:45 PM   #78
B and B's Avatar
I also use whit lithium grease. Today's trip things were groaning a but so it gets lubed before we head back home. I have asked for a lift kit at Goshen. At times backing in on an angle almost touch the back corner of the box to the underside of the fifth wheel. I have come close to the cab on the same angle, can not do 90 degree turn going in the driveway at home.
Sent from my Z30 using Forest River Forums mobile app
B and B is online now   Reply With Quote
Old 07-11-2014, 08:47 PM   #79
Is yours activated?
Old 07-11-2014, 08:55 PM   #80
5er_tom's Avatar
I have about 25,000 miles on mine, always activated. Was easy to manually turn at first, but tightened up after a few months. Impossible to manually turn now.
Tom & Renιe
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
